trying to keep this thread going with my 5.7 hemi wiring issue's-
just using the stock factory wire harness.
have some of the electrics together as a mock set up. have bypassed the
ignition switch for now.
the start circuit is connected to battery, starter thru a relay and is cranking.
also have my gas system installed with a pressure gage, electric pump, lines
regulator with all good and working.
when both are switched on -- good fuel and cranking but no spark yet?
hoping someone has gone thru this and can help.
