Author Topic: Gear Vendors Info  (Read 5454 times)
Offline Carlwalski
Re: Gear Vendors Info
« Reply #15 on: April 27, 2006 - 06:50:31 PM »
Any stock 727 will handle 500hp+ easily....just, performance wise you'll want it shifting quicker.  :thumbsup:
904's just as good, though not quite as strong, but you gain on average 0.10th on 1/4 in a same set up car.
But with the mods needed to make it as tough as a stock 727, the 727 could use that money on engine mods instead....
 :2cents:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline JimCuda
  • MOPAR > Move Over Plymouth Approaching Rapidly
« Reply #16 on: April 27, 2006 - 07:20:04 PM »
You would need a stock rebuild kit. Would you want bushings,filter, all thrust washers ,both bands etc( in other words everything new) ?
Yes they did but they were a little heavier duty than your 340 727
That being said, where can I find the most complete kit containing the best parts for a rebuild kit, one maybe with an overdrive for the best price? B&M? Summit? Jegs? GearVendors? TracTrans ;D ?
Need the info!!! :swaying:
Offline tactransman
« Reply #17 on: April 27, 2006 - 09:04:56 PM »
You can call me, my number is on my web site www.tactrans.com
  Terry  :cheers:
Terry-tactransman
Union, Mo.
Offline JimCuda
« Reply #18 on: April 27, 2006 - 10:14:17 PM »
Will you be there on Sat?
Offline tactransman
« Reply #19 on: April 28, 2006 - 04:58:29 AM »
Yes , From about 8:00 am to 11:00 am Central Time. :cheers:
Terry-tactransman
Union, Mo.
Offline tactransman
« Reply #20 on: April 28, 2006 - 08:31:38 AM »
NZ do you have an underneath picture of your GV unit installed in the car? :working:
Terry-tactransman
Union, Mo.
Offline 73cuda426
« Reply #21 on: April 28, 2006 - 12:12:20 PM »
I spoke to gear vendors about the unit for $450 and that we should wait until the summer to get everything worked out.
Offline tactransman
« Reply #22 on: April 28, 2006 - 12:39:03 PM »
 :2cents:
Exactly   :iagree:
Terry-tactransman
Union, Mo.
Offline Carlwalski
« Reply #23 on: April 28, 2006 - 06:24:49 PM »
Not yet my friend but once the car is finished and had it's test runs we're going to hoist it up and take some.
Mods needed for the GV gear box to fit the Challenger were:
 - Custom made driveshaft (you can use your original, just shorten it).
 - About 1"-1-2" of clearance around the unit in the underside shell, which is placed directly after tailshaft.
 - H-pipe exhausts should need no mods to fit, X-Pipes require the right tube to be bent about 0.5"-1" to clear.
 - Heat shield around the GV sump as it is about 0.5" from the exhaust.
 :cheers:
