I have the same one, the only problem I have had is with the gun. The gun is a cheap 10 dollar piece, you my want to at least up grade that as the rest of the unit is good. The other problem was as stated before, make sure you trap that moisture.
btw, the problem with the gun is that the valve is actually a rubber hose that is pinched by a steel pin, guess what happens, the steel pin cuts the hose, valve is now an open hose but what is worse is that it is stuck open but not fully opened so it made it useless.
As a side note, that same gun is used in every sandblaster in that price range, a good gun should cost 50-80 dollars. Or, it could be I just have bad luck.
Just to repeat as stated earlier... oh my, what a mess it makes of a two car garage... I will never get that sand out, every box I move has sand on it, in it, behind it... And that was just one fender... sending my car off to the pros for the rest of the work as time is money and more time is spent cleaning up than doing the car.
