Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
Why would you do this
« previous
next »
Print
Pages: [
1
Author
Topic: Why would you do this (Read 1040 times)
ohio cuda
Jr. Member
on:
April 26, 2006 - 07:04:43 PM »
Can someone help me understand why you would plug 1 side of the engines lifter oil passages? Did they crack and then run solid lifters? This is a 340 TA Block I like to save if possible.
Last Edit: April 26, 2006 - 07:06:26 PM by ohio cuda
Logged
ohio cuda
Jr. Member
Re: Why would you do this
Reply #1 on:
April 26, 2006 - 07:05:45 PM »
As you can see going down one side of the block everyone is pluged
Last Edit: April 26, 2006 - 07:07:16 PM by ohio cuda
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #2 on:
April 27, 2006 - 12:10:16 AM »
it forces more oil to the mains & was common with roller cams to do this
Logged
tactransman
Sr. Resident
1973 Challenger- Member here since April 14, 2006
Reply #3 on:
April 28, 2006 - 11:31:49 AM »
Chryco is right again! Mopar use to sell a kit that was two brass tubes that you shoved down thru the oil gallerys from the end , then it had a tool that was rounded on the end that you put into the lifter hole to " peen" the tube out of the way of the lifter.It is kind of out of date practice because the roller lifter bodies now are made so they don't dump all the oil pressure out the lifter holes.
Logged
Terry
-tactransman
Union, Mo.
ShelbyDogg
Sr. Resident
Reply #4 on:
April 28, 2006 - 02:50:43 PM »
It also kept the oil to the mains in case the pushrods bent and the lifters shot out of the bores.
Logged
ohio cuda
Jr. Member
Reply #5 on:
April 28, 2006 - 07:24:12 PM »
I'm learning a lot for a 52 year old. I had some time today and your right on. I started scratching them and I thought it was copper. Now comes the fun part of getting them out. Thanks for the insight guys.
Logged
ShelbyDogg
Sr. Resident
Reply #6 on:
April 29, 2006 - 03:58:18 PM »
Behind the PLUG, you might have to thread something into the tube to pull it out. Try wedging the proper sized pipe tap in there to grab on to it.
Logged
daves70
Guest
Reply #7 on:
April 29, 2006 - 04:14:32 PM »
Like I always say, if you need an answer to a Mopar ? Chryco or somebody here will have the answer!!
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
