Author Topic: finally got my blower  (Read 827 times)
Offline KellysCuda aircard
  • Its good to be blown
« on: April 26, 2006 - 08:50:33 PM »
whoo   hoooo,  finally got my blower, CP has it bolted on and only a day or two away from a start up. Its got a 60 over bore with diamond blower pistons (8 to 1) lunati cam, scat rods, roller valve train, eddy heads that Niel has worked over, tti 2 inch primarys with 3.5 inch collectors, series 40 flow masters, msd with billit distributer, 8-71 BDS with dual 750 demons on top. The trans is a 727 tf with revers valve body and custom built 10 inch torque, followed with a custom drive shaft, 355 gears, auburn posi, mosier axils and green bearing kit.   I hope she flies.
Offline zerfetzen
  • 'Cuda, should'a, would'a...you lost.
Re: finally got my blower
« Reply #1 on: April 26, 2006 - 09:02:35 PM »
Lookin' good. What kind of hood are you using?
Offline EVIL72
« Reply #2 on: April 26, 2006 - 09:30:08 PM »
The kind with a really big hole in it!  :roflsmiley:
ROB
1972 Dodge Challenger 340ci
1970 Pro Street Duster (Under Construction)
Offline zerfetzen
« Reply #3 on: April 27, 2006 - 02:11:02 PM »
Good one Evil  :bigsmile:
What I meant was, are you going to use a steel flat hood and cut as needed, or will you fiberglass it?  Just curious.
« Reply #4 on: April 27, 2006 - 03:08:20 PM »
Not to sure yet, havent gotten that far as to worry about a hood, but I should. Probly what ever I can find for now.I dont really want to cut up my hood. Mabey I could look for a fiberglass hood.
