Author Topic: Updated 4 spd info  (Read 12927 times)
Offline 72hemi
  • MEMBER SINCE JANUARY 2006
Re: Updated 4 spd info
« Reply #15 on: October 18, 2009 - 01:27:31 PM »
What are the bolt sizes for the bellhousing both to mount the bellhousing to the block and to bolt the transmission to the bellhousing? Also the pressure plate attachment bolts, what size are they?
1996 Dodge Viper GTS Coupe
Offline 72rtchallenger
  • 72 to 70 clone
    • cardomain
« Reply #16 on: October 18, 2009 - 02:15:12 PM »
unsure of exact sizes,,bought everything out of another ebody ,,replaced flywheel due to heat cracks,,every bolt came with the setup,,but cant remember the sizes
72rtchallenger
what happens in the garage
stays in the garage
« Reply #17 on: October 18, 2009 - 02:38:50 PM »
I would like the procudure doing a thread on how to measure bellhousing run out using a dial indicator.
My questions are:
If the bellhousing input hole looks un scarred, is it still important to check this?
How is it corrected? Or do you replace bellhousing?
What would I be looking for?
How much tolorance allowed?
Offline Changin Gears
« Reply #18 on: October 18, 2009 - 04:20:18 PM »
The procedure is in the service manual.  Every factory bellhousing I have checked, except for 1, has been within spec.  The blow-proofs are always out.
« Reply #19 on: October 19, 2009 - 02:40:46 AM »
the bolts are 3/8" x 1 1/4 long for the top of the bell , 7/16 x 2.5" long for the bottom corners into the block  &
7/16 x 1 1/4long  to hold the tranny on
Offline chevyconvert
  • HvacMan
  • Member since November 04, 2005
« Reply #20 on: October 31, 2009 - 08:16:42 PM »
I'd say this is considered a colder month now. Is a trip in order?  Or was it fixed?
nah...still vibrating....BURRRRRR
 :bigsmile:
Eric
'70 Hemi Orange RT/SE 440 Six Pack Pistol-Grip 4 speed
Bay Area California
« Reply #21 on: November 01, 2009 - 06:46:52 PM »
LOL Give him another month! It will be colder and he might have his own car together by then!
« Reply #22 on: November 02, 2009 - 11:33:08 AM »
road trip sounds like a good idea , I am vibrating or is that shivering  :crazy:
