Author Topic: rear main seal oil leak  (Read 1363 times)
Offline haplo
  • no i am not
« on: April 28, 2006 - 06:19:23 AM »
 Help  have a 1974 360 stroked to a 417, oil leaking at rear seal, droped the oil pan seal is in correct.   any thoughts?
Offline Follicly Challenged
Re: rear main seal oil leak
« Reply #1 on: April 28, 2006 - 08:47:19 AM »
Very frustrating problem, my condolescences.
Anyways, just a thought, one more possibility to check next time you're in there, is the groove that holds the seal in the block "centered" ?
I've seen blocks where the groove is actually slightly staggered to one side, whereas, when you're looking at the seal compression against the crank in the block, with the rear cap off of course, you can actually "SEE" the lip contacting and compressing more on one side than the other.
Did the same thing as you 4 times before I caught it !
Really frustrating !
The "fix" for me was to stagger the seal across the parting line about 1/4" and use the cap when re-installing to drag the seal into contact on the offending side.
Just something to check, hope you find the problem, I really feel for you ! Good luck !
« Reply #2 on: April 28, 2006 - 09:29:10 AM »
once I thought I had a leaking rear main, 2 professional mechanics told me so. Later I traced oil to rear of intake where gasket seams at corner were not together.
« Reply #3 on: April 28, 2006 - 10:37:20 AM »
I had a small leak at the oil sender at the rear of the block that seemed to be  the rear main
Offline JCWCuda
« Reply #4 on: April 28, 2006 - 12:24:24 PM »
Sometimes the sending units will blow oil right out of the top and it then runs down the back of the block
1974 Barracuda 360
2008 Ram 1500 Quad Cab 5.7l Hemi
1990 Jeep Cherokee 4.0l
Gone but not forgotten
1967 Barracuda 273
1976 Charger 318
2003 Dakota Quad Cab 4.7l
1988 Jeep Cherokee 4.0l
daves70
« Reply #5 on: April 29, 2006 - 04:19:11 PM »
 :clueless: Could be any of the above fore mentioned. Could even be a valve cover leaking at the rear and running down. It's a process of elimination!  :grinyes:
Offline R/T
  • Johnson City TN
« Reply #6 on: April 30, 2006 - 04:46:27 PM »
I had a 360 in a 1977 road runner and if you nailed the throttle hard off the line it would snap the oil sending unit off. New motor mounts and it would still snap it off so I finally built a solid motor mount  for it after that it would lift the front tires
1973 Challenger (OO/=====\OO)  440
Hemis and Harleys
2008 Dodge Ram Big Horn Edition  5.7 Hemi
