Author Topic: Stock Compression Ratio 71 Cuda 383?  (Read 937 times)
Offline Total BS
  • '71 Carrabuda Baby!
« on: April 29, 2006 - 11:27:38 PM »
Hi gang,
I am trying to order a ignition system for my 71 Cuda and the company is asking me what the stock compression ratio is to best supply what I need.  Can anyone help me out.  I have a 71 383 4-BBL, auto w/ A/C.  Any help would be appreciated.
1971 'Cuda 383
1970 Chevelle SS LS6
1999 Durango
-New Joisey-
Offline Ghost
  • I miss my Barracuda :(
Re: Stock Compression Ratio 71 Cuda 383?
« Reply #1 on: April 29, 2006 - 11:33:34 PM »
8.5 to 1.
Offline Cuda Cody
  • Vancouver, WA
« Reply #2 on: April 30, 2006 - 01:11:36 AM »
In 1970 a 383 was 8.7:1 for a 2 bbl and 9.5:1 for a 4 bbl (per the factory manual).  Not sure why they would drop so much for the 71's?
Is your engine still all stock?  If not, you're in the same club as I am.  You really have no way of being sure.  Changing the pistons, cam or heads can changes the compression ratio a ton!
« Last Edit: April 30, 2006 - 01:28:23 AM by C O D Y »
Offline Total BS
« Reply #3 on: April 30, 2006 - 10:14:41 AM »
Thanks guys...
Cody, as far as I know the only thing that was changed was the carburator and intake at some point. I just had the engine rebuilt to stock with a little cam upgrade which I have the paper work on.  That is why I am trying to figure out the original compression ratio so that they can put together the right package for my setup. Being technically inedpt, its not easy...lol
1971 'Cuda 383
1999 Durango
-New Joisey-
Offline FY1 RT SE
« Reply #4 on: April 30, 2006 - 11:34:18 AM »
A '71 383 magnum produced 35 hp less than the '70 magnum.
Offline Ghost
« Reply #5 on: April 30, 2006 - 02:37:26 PM »
Emissions regs.  Every HiPo engine, except the HEMI I believe, lost some compression.
