Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
dome light not working
« previous
next »
Print
Pages: [
1
Author
Topic: dome light not working (Read 2712 times)
Got JOB
Full Member
Member since 2-14-06
on:
May 01, 2006 - 06:51:45 PM »
does anyone know how the dome light gets 12v. to make it work. new bulb, door switches good, good harness but can not get voltage anywhere. does the key buzzer have to be plugged in? car is a 74 challenger.
Logged
70 T/A Plum crazy
71 vert. viper red
74 Rallye triple black ( sold )
76 Aspen Wagon
West Georgia
GreenFish
Sr. Member
Re: dome light not working
Reply #1 on:
May 02, 2006 - 07:30:53 AM »
Let me take a look at my wireing diagram.. Ill try to look tonight.
Logged
Bullitt-
Permanent Resident
Better Things To Come Member Since 2/16/06
Reply #2 on:
May 02, 2006 - 08:31:21 AM »
There is a harness connector on my '73 in the trunk over the Left rear wheel well.
Logged
Wade 73 Rallye 340..'77 Millennium Falcon...13 R/T Classic
Huntsville, AL
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
May 02, 2006 - 09:23:16 AM »
the power runs from the fuse box to the emergency flasher then the pink wire to the stop light switch thewn to the dome light circuit
Logged
Got JOB
Full Member
Reply #4 on:
May 03, 2006 - 08:39:37 PM »
thanks, I can follow the pink wire but it goes into the taped harness. Should 12v. be on one side of the door switch or is the switch just completeing a ground circuit when the door is opened?
Logged
70 T/A Plum crazy
71 vert. viper red
76 Aspen Wagon
West Georgia
Bullitt-
Permanent Resident
Reply #5 on:
May 03, 2006 - 08:49:00 PM »
door switch provides ground, there should always be 12v+ to bulb
Logged
Huntsville, AL
383 SE
Jr. Member
Reply #6 on:
May 04, 2006 - 07:28:03 PM »
Quote from: bullitt99 on May 03, 2006 - 08:49:00 PM
I also have no dome light in my 70 SE overhead console. I seem to have a major short as I have to leave the connector in the trunk unplugged or the fuse blows controling the brake lights. I just printed out the wiring diagram and hope to find the problem but it looks like a huge task! In addition to the dome light, I have the trunk light, map light and lights in the overhead console that are on the same circuit. If anyone has any ideas as to where to start looking, I'm open to sugestions!
Thanks, 383 SE
Logged
Bullitt-
Permanent Resident
Reply #7 on:
May 04, 2006 - 07:49:01 PM »
If disconnecting the harness in the trunk stops the problem you have eliminated everything before that plug therefore I would assume that the problem is in the wiring or a fixtures after the plug. Maybe check for shorts begging at the harness plug, go to each fixture & disconnect & see if short goes away. Of course it could be in the harness itself which could be removed, with some difficulty, from above the headliner.
Logged
Huntsville, AL
383 SE
Jr. Member
Reply #8 on:
May 04, 2006 - 07:59:33 PM »
I found one pinched wire and fixed it but the problem is still there. No interior lights at all. There might be more above the console, I'll have to check again.
Thanks
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
