Author Topic: Rally Wheel Question  (Read 1355 times)
Offline Blackcuda
« on: May 02, 2006 - 07:27:30 AM »
I have a set of 15" Rallys with tires that I'm selling, there are 3 bolts on the back of the wheel holding the center cap. Are these wheels 15x7 or 15x6.5?
Thanks for the help.
Re: Rally Wheel Question
« Reply #1 on: May 02, 2006 - 09:25:46 AM »
I assume you have a tape measure ?
 measure across the rim inside the lip where the bead of tire sits
Offline Blackcuda
« Reply #2 on: May 02, 2006 - 09:52:47 AM »
The tire is mounted on the rim or I would have tried that. These are a old set of wheels off a 71 Challenger, I was wondering if it is true that a 7" wide wheel uses 5 bolts to mount the center cap or 3? I was told if it has only 3 bolts it's a 6.5" wide wheel. Is this true?
« Reply #3 on: May 02, 2006 - 04:59:45 PM »
 :clueless:
 You are basing this on the center cap? They all should have 5 holes for screws to hold them on. Maybe someone took a short-cut with yours? Are there 2 extra holes in the wheel that aren't being used?
Offline ROMI
  • 71 Challenger R/T 340 4 speed, Lapeer Michigan
« Reply #4 on: May 02, 2006 - 05:34:44 PM »
Once you figure it out please post here because I'm looking for a pair (2) of 15's
You could PM me if you'd like.
Offline FY1 RT SE
« Reply #5 on: May 02, 2006 - 05:51:41 PM »
'70-'71 wheels have 5 holes, '72 up have 3 holes, no way of knowing without looking at either the part number or the stampings on the inner rim.
Offline Blackcuda
« Reply #6 on: May 02, 2006 - 08:51:21 PM »
I was told that if the wheels only have 3 bolts the wheels are 15x6.5. Could you tell me what year they stopped making the 15x6.5's?
« Reply #7 on: May 02, 2006 - 11:23:14 PM »
78 or so was the last year for the 6.5" rims
