5.7 hemi
Author Topic: 5.7 hemi  (Read 3761 times)
Offline 440WhiteBoy
5.7 hemi
« on: May 02, 2006 - 09:07:37 AM »
checking to see if anyone is doing a 5.7 hemi swap-?
if so are there any threads that share some info about the wiring issue's using
the factory harness?
*so far I have the starter circuit wired in as a mock up by passing
the ignition switch and its cranking.
have my gas system installed with good presure to the injectors.
while cranking so far I have no spark?
have my 02 sensors in the headers connected to the outgoing jacks.
engine harness all together. did I miss a pin or jack to wire in someplace?
hoping someone will chime in with some idea's-
They only see ***STARS***
when hit by a MOPAR !!!
Offline GreenFish
Re: 5.7 hemi
« Reply #1 on: May 04, 2006 - 08:12:18 AM »
you are entering uncharted territory.. good luck! wish i could help
Offline TheCrazyCheesehead
Re: 5.7 hemi
« Reply #2 on: May 04, 2006 - 09:11:21 AM »
Dude,
go on moparts webboard and do a search for 5.7L hemi swap, And you will find a ton of info.
Later The Crazy Cheesehead
Bryan The Crazy Cheesehead
'69 340-S Fastback Barracuda
Offline 440WhiteBoy
Re: 5.7 hemi
« Reply #3 on: May 04, 2006 - 09:36:33 AM »
 hey TheCrazyCheesehead thanks,
im on that board and check it often. im getting some help.
just need to review the diagrams to find out which pin wires I need
to tap into I think.
Offline Robb
Re: 5.7 hemi
« Reply #4 on: May 04, 2006 - 01:19:16 PM »
what kind of gas mileage results are people getting with these applications swapped into E and B Bodies ?
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
Offline 440WhiteBoy
Re: 5.7 hemi
« Reply #5 on: May 05, 2006 - 06:43:26 AM »
hi robb,
so far without mine on the road yet I cant say. my guess is it will be at the least the same as any other modern vehicle with that motor in it. actually it should be even better because these older cars are much lighter in weight.
a durango I think is 6600 lbs, the ram truck is 5600 lbs. so with my 70 barracuda should weight in 3400 apx +/- 200 lbs. not to mention how much faster she should be!
if the ram truck is 16 sec at the track, does anyone know what the apx. ratio's would be per 1000 lbs vrs ?
I thought someone last year said they did upper 12's with a challenger and stock 5.7 hemi combo-?
Offline 57hemicuda
  • 5.7 hemi
Re: 5.7 hemi
« Reply #6 on: May 06, 2006 - 07:44:24 PM »
I've been driving mine for about a month,if I could keep my foot out of it I think it's getting about  18 mpg.It made 373 rear wheel horse power,with an automatic and a loose converter,should be about 450 at the crank.If I could ever get it to hook up ,it feels like mid to low 12's with out any problem   http://mysite.verizon.net/ls6ron/
Offline 440WhiteBoy
Re: 5.7 hemi
« Reply #7 on: May 07, 2006 - 09:52:17 AM »
man 18 is much better than my 440 used to get 10 -
have you tried on cement or asphalt to get her to hook?
really like the way your car turned out!
Im hopefull later to do something like youve done with the disk brakes and front suspention system. right now im all stock front to back except the drivetrain. just want to see how she performs before the swap out. also tapped out of funds. as you know once on the road with excitement somehow your pocket book will open up!
Offline Robb
Re: 5.7 hemi
« Reply #8 on: May 07, 2006 - 12:27:48 PM »
http://www.hotrodlane.cc/PDFFILES/68GTX61HEMI.pdf#search='5.7%20hemi%205%20speed%20tremec'
this is a cool link  6.1 Hemi and Keisler 5 speed
its for a B Body but the general approach and pic set is valuable material
Offline 440WhiteBoy
Re: 5.7 hemi
« Reply #9 on: May 08, 2006 - 08:38:12 AM »
good find robb-!
very nice job on a great looking car!
a 1 1/2 yrs later with my 5.7 I now wish I held out for that one!
Offline ESGEE
  • 1970 Challenger RT/SE
    • SG´s site
Re: 5.7 hemi
« Reply #10 on: May 10, 2006 - 05:54:45 AM »
That site was great, im just into to put a 5.7L in mine and i havent even started with the electrical stuff get, im more waiting to get hold of the carbintake or i will have one made otherwise its a new harness and computer and throw the one i have. Really cool that more and more people try this swap(not just the customshops), im the first in Sweden with mine what i now about...
70 Challenger RT/SE(Looking for 383 Magnum N0B196875)
70 Challenger RT/SE(Looking for 383 Magnum N0B115166)
70 Challenger SE(RT/SE clone)
69 Charger RT/SE 4speed Trackpac
70 Charger 500
Offline highspeeddirt
Re: 5.7 hemi
« Reply #11 on: June 02, 2006 - 07:52:50 PM »
......... im more waiting to get hold of the carbintake.......
Is it possible to go with a regular carb/intake setup on a 5.7?  If so, what are the factors to consider?
Butte, MT
Offline ESGEE
    • SG´s site
Re: 5.7 hemi
« Reply #12 on: June 02, 2006 - 08:04:05 PM »
At the moment they dont sell the carbintake its just on the Cratemotors, i guess they wanna make some money on the crates before letting the carbintake out on the market....
70 Charger 500
Offline 57hemicuda
  • 5.7 hemi
Re: 5.7 hemi
« Reply #13 on: June 02, 2006 - 08:21:14 PM »
Try calling Edelbrock,their carb intake should be out by now
Offline ESGEE
    • SG´s site
Re: 5.7 hemi
« Reply #14 on: June 02, 2006 - 08:24:21 PM »
Thats great news...
70 Charger 500
