Author Topic: Does anyone have bolt specs for.......  (Read 1051 times)
Offline moparnut
    • My Photo's
« on: May 03, 2006 - 09:05:54 AM »
I was wondering if anyone has bolt specs(to buy at a hardware store)for flywheel,pressure plate and 4 speed tranny bolts ect??
thanks
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
Offline tactransman
Re: Does anyone have bolt specs for.......
« Reply #1 on: May 03, 2006 - 09:11:08 AM »
Not sure of the thread pitch or size but definitely everything GRADE 8. Chryco can probably help you on that. :thumbsup:
Terry-tactransman
Union, Mo.
Offline ShelbyDogg
« Reply #2 on: May 03, 2006 - 03:30:24 PM »
All grade 8 from ACE Hardware for the bellhousing and tranny. Speed shop or Mancini for flywheel bolts. Make sure that the flywheel bolts don't go through the crank and rub the block. If you have to, grind then a little shorter.
 Make sure that the bolts don't bottom out before pulling the trans in tight. Check the hole depth with a nail then compare the bolt engagement, if it's not the same, clean out those threads with a tap. Use the longest bolts possible without bottoming.
Offline moparnut
    • My Photo's
« Reply #3 on: May 03, 2006 - 03:59:04 PM »
THanks ROb,I guess i can pull one of the bolts from the tranny on my chally to match them up at the hardware store,along with the bell bolts
Offline ShelbyDogg
« Reply #4 on: May 03, 2006 - 09:35:24 PM »
Just take that Bellhousing into the store with you. The 4 trans bolt holes are there, and 2 bell housing bolts halfway down are threaded also.  The trans is about 1/2" thick at it's ears.  Get some good lock washers with the bolts.
Offline moparnut
    • My Photo's
« Reply #5 on: May 03, 2006 - 11:38:06 PM »
DOH good idea,lol.At least someone's thinkin,I'm gettin Old
thanks
« Reply #6 on: May 04, 2006 - 01:37:20 AM »
I use Arp flywheel bolts ,7/16 X 1" with fine thread is what you need , in a package of 6
4 bolts- 7/16 X 1.5" coarse thread for the tranny to bel
4- 3/8" X 1.25" long coarse thread & 2- 7/16 x 2"  to bolt the bel to the engine
Offline moparnut
    • My Photo's
« Reply #7 on: May 04, 2006 - 10:20:50 AM »
thanks :thumbsup:
