Author Topic: smoke...does a body good  (Read 5033 times)
Offline GhettoPop
  • I need a new pair of hookers
« on: April 02, 2003 - 12:00:14 AM »
nice
[attachment deleted by admin]
MOPAR 4 LIFE!
Offline GhettoPop
Re:smoke...does a body good
« Reply #1 on: April 02, 2003 - 12:02:21 AM »
u can almost smell it
MOPAR 4 LIFE!
lemonboy69
« Reply #2 on: April 02, 2003 - 11:48:57 AM »
Looks like you don't have sure-grip...  ::) ;D ;D ;D Don't feel bad man... I love doing 1 wheeled burnouts too!!!! It's a great accomplishment to be able to make the rear end disappear with 1 wheel!!!! ;D ;D ;D ;D Great car...
LB
Offline GhettoPop
« Reply #3 on: April 02, 2003 - 01:53:12 PM »
i dunno what the deal is, the car has a posi rear, shouldnt both tires hook up? can the wrong gear oil make only 1 tire hook?
MOPAR 4 LIFE!
Offline 69ChargerRT
  • Its the car, right? Chicks love the car. - Batman
    • Daisy - My 1969 Dodge Charger R/T
« Reply #4 on: April 02, 2003 - 04:05:03 PM »
id definitely look into that.  if its a "Sure Grip" limited slip diff both tires should be spinning there.  i really doubt oil would cause only one to spin.  are you sure you have a limited slip?
Offline GhettoPop
« Reply #5 on: April 02, 2003 - 05:50:26 PM »
to tell u the truth, not sure if i have sure grip, i will look into my paperwork
what exectly does a limited slip do? simply lock both tires? so whats the exact definition of a posi?
MOPAR 4 LIFE!
Offline 69ChargerRT
« Reply #6 on: April 02, 2003 - 07:44:40 PM »
someone could probably give a more techinical definition then i could, but it keeps the wheels spinning in synchronous.  if your not sure you have it, judging by the pics i would say you dont.  it helps traction and handling, worth getting if you dont have it.
lemonboy69
« Reply #7 on: April 02, 2003 - 08:55:53 PM »
Limited slip/Sure-grip: Special gearing keeps both tires spinning versus 1 when traction is lost.... soooo... if you can break one tire loose, you've got both going!!!  :D :D :D :D
LB
« Reply #8 on: April 02, 2003 - 11:02:16 PM »
If you have a sure grip , both tires "should' spin  however 30 year old cone style sure grips tend to wear out allowing the cone to bottom out allowing the diff to lock sometimes & not others , if you jack up the diff & spin 1 tire , in neutral, & the other tire rotates the same direction   you have a sure grip  ;)
Offline GhettoPop
« Reply #9 on: April 02, 2003 - 11:17:44 PM »
Yeah thats what i thought. i remember jackin it up and both tires spun in same direction, so maybe the diff just didnt lock when i was layin down patches in those pics. its possible, cuz when i usually lay one down i get two rubber trails, not one! but it was such a long time ago that i jacked the rear up and spun the tire, i have a bad memory, only one way to find out.......hope its not raining this weekend!
MOPAR 4 LIFE!
lemonboy69
« Reply #10 on: April 03, 2003 - 02:27:02 AM »
Goo.... no, great answer!!!  ;D ;D Let's see some pics with 2 patches now....!!!!!!  ;D ;D ;D
LB
Offline DodgeFreak
  • Cars and trucks are my friends..
« Reply #11 on: April 05, 2003 - 11:00:36 PM »
Limited slip\sure grip.... newer ones have clutch discs that when one tire starts to spin the clutchs kick the other side in so to speak.  no for dog leg well thats just when one tire spins like in the picture.  posi is where there is a spool that conects the to axles and will allow no slipping what so ever its a live axle like on a racing 4 wheeler or something.  hope that clears somethings up.
74 Plymouth Duster- restoring
77 Dodge D150 shortbox- as long as i don't change my mind will be a step side dually diesel or a 383 powered truck
04 durango 4.7
Offline GhettoPop
« Reply #12 on: April 06, 2003 - 01:37:04 AM »
lost me with the dog leg part.... ???
MOPAR 4 LIFE!
Offline DodgeFreak
« Reply #13 on: April 06, 2003 - 09:23:10 PM »
DogLeg is what they call the differential when it has the spidergears.  The tire with less traction is the one that spins.  Thats called dogleg.  Does that help... i know what it is but i just can't really explain it.
04 durango 4.7
Offline rtgambit
  • Member since March 31, 2003
« Reply #14 on: April 12, 2003 - 01:15:59 PM »
Hey, shouldn't the passenger tire be spinning instead of the drivers tire?
Every burnout I've done /w peg-leggers I always spin the pass. side.
Something to do with the engine rotation and the torque planting the drivers side down and lifting the pass. side.
Somebody please correct me if I'm wrong... ;) I'm still fairly new to all this, ya know?
Matthew
1967 Dodge Dart GT
1971 Dodge Challenger R/T
2014 Ram 1500
