Author Topic: Cracked flexplate  (Read 1466 times)
Offline 7yr
Cracked flexplate
« on: May 08, 2006 - 08:09:08 AM »
I replaced my bolts on my flexplate (http://www.cuda-challenger.com/cc/index.php?topic=20689.0), only to see that my flexplate was cracked.
I am guessing that since two of the bolts on the flexplate were loose, that means all the force was placed on the remaining two bolts, which caused it to crack.
1) Is there a stronger flexplate you can use to replace the original?
2) I am guessing there is no way around it, you HAVE to drop the transmission to replace it, right?
I hate that -a $70 part, but about 56 hours of labor.....
Offline tactransman
Re: Cracked flexplate
« Reply #1 on: May 08, 2006 - 09:25:35 AM »
(1) A Mopar Performance one is stronger( part # P4876821) :swaying:
(2) Yes
MAKE SURE BOTH DOWEL PINS ARE IN THE  BACK OF THE ENGINE !!!!!!!!!!!!!!!
« Last Edit: May 08, 2006 - 11:48:33 AM by tactransman »
Terry-tactransman
Union, Mo.
Offline ShelbyDogg
« Reply #2 on: May 08, 2006 - 10:57:51 PM »
7Yr, Before you start, get a rolling tranny jack from Harbor Freight for $49. It straps around the tranny and tilts a little.  After you unbolt the 4 flex-plate bolts, bolt a small box end angled wrench to one of those lower cover bolt holes, and tighten it up against the converter. It'll hold your torque converter all the way in your front pump while you pull the tranny away from the engine.   Now after unbolting the the tranny, driveshaft and linkage, you can roll the trans just back far enough to change that plate, then slide it back together.  Should only take about 4 hours max, but watch out for tranny fluid dumping out of the tailshaft and filler tube hole. (this would be a good time to drop the pan and add a drain plug)
Offline moparclown
« Reply #3 on: May 09, 2006 - 04:35:43 PM »
I dont know if this will help but i just bought a hemi flex plate part#p4529751 and the large bolt kit part#4529592 the bolt kit is the seven sixteenth bolts for the torque converter.the plate cost 33 dollars and the bolt kit cost 16 dollars and i got these from my local mopar dealer.
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #4 on: May 09, 2006 - 05:43:46 PM »
B&M flexpaltes are SFI approved and avialible from Summit or any performance dealer just be sure to get the right part #(balance) for your engine.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline tactransman
« Reply #5 on: May 10, 2006 - 05:33:22 AM »
If you have the stock size converter bolts you will want the Mopar flexplate ( part # P4876821) .  :thumbsup:
« Last Edit: May 10, 2006 - 07:21:02 AM by tactransman »
Terry-tactransman
Union, Mo.
