Author Topic: What are you using to hold trunk open?  (Read 3120 times)
Offline Katfish
  • 70 Challenger
« on: May 08, 2006 - 05:18:14 PM »
There has to be a better way than my PVC method.  What are you using to hold trunk open when they have a heavy spoiler?  A hood prop from another car might be an idea?  Like to see what the innovative people have done?
Thx
daves70
Re: What are you using to hold trunk open?
« Reply #1 on: May 08, 2006 - 05:24:42 PM »
I don't know, mine stays open on its own. :grinyes:
Offline crcarch
  • Happiness is having the time and the money!
  • "No, it's not a Charger!"
    • A little history and restoration pics on Cardomain
« Reply #2 on: May 08, 2006 - 06:08:14 PM »
Are your rods set correctly?  The holes in the vertical supports allow tension adjustment.  They may be set too weakly.
00/===\00 73 Challenger 440-4V/AT  8/--+--\8 09 Ram 1500  0o\==/o0 05 Crossfire Roadster OO(#####SRT)OO 10 Challenger
Offline Killer_Mopar
« Reply #3 on: May 08, 2006 - 06:18:27 PM »
What he said. You shouldnt have to use any trunk prop.
Offline moparnut
    • My Photo's
« Reply #4 on: May 08, 2006 - 07:12:25 PM »
Take off the spoiler and use it to hold the trunk open,lol,sorry couldnt resist :roflsmiley:
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
Offline 71 DEPUTY
  • IF YOU CAN'T DODGE IT--RAM IT!
    • Cardomain
« Reply #5 on: May 08, 2006 - 07:23:00 PM »
had to re engineer my own with gas strut units. let me know if ya want pics!!!
John Mac
Offline A110235
  • '71 Challenger JH23G1B
« Reply #6 on: May 08, 2006 - 08:03:28 PM »
John Mac
I have thought about doing something like that, so ya, I'd like to see some pics.   :grinyes:
Nashville, TN         Member since October 09, 2004
Offline 71 DEPUTY
    • Cardomain
« Reply #7 on: May 08, 2006 - 09:32:31 PM »
ok
ball unit on hinge side
bolts thru to rear seat
need on both sides!!!
« Last Edit: May 09, 2006 - 08:28:50 AM by Rev-It-Up »
Offline Katfish
  • 70 Challenger
« Reply #8 on: May 09, 2006 - 05:28:00 AM »
Deputy,
Do you have a pic from further out?  I'm not seeing whole set-up.  I've had 2 Challengers, and neither would hold lid open with a T/A spoiler?
I'd like to hear from a factory T/A owner, are factory rods strong enough or different?
Offline 71 DEPUTY
    • Cardomain
« Reply #9 on: May 09, 2006 - 06:38:33 AM »
Kat- will get some other pics.
I have a Gull wing on the trunk- it will hold it up!!!
Offline rusty dodge
  • 74 challenger 440-727-3:55
« Reply #10 on: May 09, 2006 - 12:20:52 PM »
When I added the T/A spoiler to mine, I moved the torsion springs over to a different slot. Works perfect.
Offline ShelbyDogg
« Reply #11 on: May 09, 2006 - 05:46:09 PM »
I added a spoiler to mine and adjusted both rods to a tighter hole too. Have another mopar guy look at your trunk torsion rods.
« Reply #12 on: May 09, 2006 - 05:50:22 PM »
Rob,
  To make them stiffer, do I need to move them forward, or backward as far as the holes go? Mine is kinda not as stiff as I would like since I put on the go-wing.  :1zhelp:
Offline ShelbyDogg
« Reply #13 on: May 09, 2006 - 06:04:42 PM »
Pull them towards you.  I use the biggest craftsman screwdriver that I have, stick it in from the bottom to hold the rod, use something else to slide it out of the hole, then pull towards you to the next hole.  Be carefull, the trunk might drop and hit your head.  Here I am drawing again.....
« Last Edit: May 09, 2006 - 06:10:08 PM by shelbydogg »
« Reply #14 on: May 09, 2006 - 06:10:31 PM »
Thanks Rob,
  If I remember correctly, I think I have one more slot to go in that direction. As far as hitting my head... I have banged it enough on the hood-latch thingie in the engine compartment. I'm used to that by now.  :lol:  :lol2:
