Author Topic: Dana 60 Strange Rear Ends For Mopars  (Read 2860 times)
Offline zokster
« on: May 09, 2006 - 06:56:59 AM »
 I can get the dana 60 as a bolt in replacement for the E-B-A bodies. Rear ends come with leaf spring mounts welded on. S/T series 35 spline axles, 1/2" studs, axle bearings, Trac/Lok posi unit, standard gear set, U1600 pinion yoke (1350), chrome cover, breather vent, filler & drain plugs, fully set up. $1,675.00 + shipping. Shipping is cheaper If dropped off at a business. Upgrades available. Race dana's with spool and race axles in 35 or 40 spline available. Solid or gun drilled axles. These rear ends are Strange Engineering rear ends and will be drop shipped from Strange Eng's Warehouse. Shipping charges are established after order is filled. I might be able to get a general idea on shipping charges if I know your zip code.
  I also build rear ends for drag racing/Pro Street applications. Narrowing and welding 4-link or ladderbar brackets, shock mounts, anti-roll tabs, wheelie bar tabs.  Complete race car/ Pro Street car chassis shop. Tube chassis in chrome-moly or mild steel. Bare chassis to complete rollers. Also do back half cars.
  Thank You: Michael Steele @ HEADS UP CHASSIS. 850-675-0176 or e-mail me  at     zokster1@aol.com
