Author Topic: Bell Housing Question  (Read 849 times)
Offline cjm
  • 70 Cuda - In Progress.....
« on: May 10, 2006 - 07:41:06 AM »
I have a 70 Cuda that is coded for a 383hp 4sp that currently has a 340 in it with the original 4sp tranny. I have another 383 that I am planning to put back in to it. I know that the bell housing is different and I need to find one. What year (years) (68 -77???) bell housing would be compatible for my application ? It's funny because every time I look on ebay the big blocks' housing is at least 5 times the cost of the small blocks'. I want to make sure that I get the right one.... Also, any aftermarket housings for mopar bb's??
Thanks in advance....
Re: Bell Housing Question
« Reply #1 on: May 10, 2006 - 10:23:51 AM »
ti depend what flywheel you use , you can use either the 10.5" /10,95" with the alum bel & 130 tooth flywheel from 71 up  or the 11" with the 143 tooth flywheel & the cast bel  used up to 69
 Passion makes there own new casting , Brewers has reconditioned ones & possibly there own new casting as well also Keisler has a nice heavier bel but I am not a fan of dealing with Keisler
Offline ShelbyDogg
« Reply #2 on: May 10, 2006 - 01:26:46 PM »
Make sure that you get the Aluminum one with the 4.8" front bearing hole.   I had another big-block one that was cast iron with the smaller 4.3" hole.  The aluminum one was the correct one for that year 383.
