Emblem removal help
Author Topic: Emblem removal help  (Read 709 times)
Offline scf100
  • FAST LANE FOREVER!
Emblem removal help
« on: May 10, 2006 - 10:44:06 AM »
I need to put new emblems on the trunk of my 70 Challenger......CHALLENGER    RT ones....the new ones stick on so I assume the old ones do too......what is the best way to remove the old ones?
Thanks,
stuart
1970 Challenger R/T convertible 383…. 4-speed…3.91 suregrip
Triple Black
kudakidd
Re: Emblem removal help
« Reply #1 on: May 10, 2006 - 10:51:08 AM »
Your wife's hairdryer and isoprophyl alcohol
Offline Killer_Mopar
« Reply #2 on: May 10, 2006 - 11:03:28 AM »
What he said, plus you might want to get a small plastic bodyfiller spreader so you can get under the emblem for some leverage when you first start. Floss works too, but it breaks too often.
Offline Wang
  • "just hangin' out"
    • valleyautoworks.net
« Reply #3 on: May 18, 2006 - 03:32:58 PM »
a 1" putty knife with the leading edge sharpened works great with
SOME CARE !!! or If you like spending money,, 3M makes a emblem/ sidemoulding removal tool that you use with a air chisel. After the
emblem is removed be certain to remove ALL old adheasive residue
before attempting to install your new emblems.
Hurry,, Duane the tub,,I'm Dwouning....
Offline falcon50flier
« Reply #4 on: May 18, 2006 - 07:49:39 PM »
Home depot, 1" plastic scraper, in the paint dept, they're a white poly plastic, very forgiving and not knife edge sharp, by Hyde Mfg (maker of all good drywall tools). Equivalent of much more expensive body shop tools for about $1.
As above recommendation, heat gun or hair dryer, and PATIENCE. You can try to soften the adhesive with a little rubbing alcohol first, but the heat is what will release the bond (no fires pls).
70 Challenger convertible
518 cid Hemi, TF727, 3.73 Dana 60
