Author Topic: 308 small block head Questions  (Read 1478 times)
Offline loco340cuda
« on: May 11, 2006 - 07:55:20 AM »
What are the best years for these heads?  Can they be bolted on a 340 with out any modifications, if not, what needs to be done to get them to work with a 340?  Will they take the stock 340 valve covers.  What do a set of these heads cost from the junk yard.
Thanks
1970 Cuda 340 4-speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
Re: 308 small block head Questions
« Reply #1 on: May 11, 2006 - 11:39:43 AM »
87-92 trucks
they bolt on & use stock valve covers
 I recommend porting them & switching to aftermarket springs & retainers to match the cam you are using as they use a short exhaust valve spring with a rotator on them
Offline loco340cuda
« Reply #2 on: May 11, 2006 - 11:48:20 AM »
Chryco, do you have the full casting number for these heads, so I can make sure I get the correct ones.  Also what motors did these come on, 318, 360 or both?  Any idea what they will cost?
Also will I need to put in bigger valves or are the stock size fine.  I'm hoping to build a 340 with about 400hp at the flywheel.
Thanks
« Reply #3 on: May 11, 2006 - 10:41:37 PM »
I can get the full #
 they were only on the 360 trucks , the 318 had a smaller version casting # 302 , they work with stock valves or you can install the larger 2.02 intakes
 I can get them for around $100 a pair depending which wrecker I hit
Offline loco340cuda
« Reply #4 on: May 12, 2006 - 08:56:49 AM »
Thanks for the info.  :thumbsup:
Also, are those heads hard to come by where you are?  I have called 3 wrecking yards in Phoenix, AZ and nobody has them.
« Last Edit: May 12, 2006 - 03:22:46 PM by loco340cuda »
« Reply #5 on: May 13, 2006 - 01:57:31 AM »
I have never had a problem getting a set
 but we have a lot of trucks here , I do have a set of ported heads available
Offline loco340cuda
« Reply #6 on: May 13, 2006 - 10:46:47 AM »
Chryco, I sent you a PM.
