Author Topic: Mopar Endorsed -Brand new Hemi, 440-6, 340 Radiators - Correct #'s - Date Coded  (Read 9715 times)
Alaskan_TA
Interesting that the above pictures are of an original tank and not the reproduction tank.
I would like to know how you knew?  :thumbsup:
Barry
Offline PlumCrazy
Hi Barry
Original radiators have depressions on the tanks, the reproductions do not.  Also many, but not all 956 radiators had the raised type "5".  I am not knocking these reproductions as they do look very good and fill a needed niche for those who do not want or can afford to spend the big dollars required to obtain an original. But as the saying goes it's only original once.
Offline alohaautomotive
The radiators can be had with the depressions for an additional fee. Look at our original pictures. That IS the reproduction radiator.
If you send me your mounting brackets I can get a radiator in a few days. Otherwise radiators with reproduced brackets are forcasted to arrive in a few weeks.
« Last Edit: June 29, 2006 - 07:09:49 AM by alohaautomotive »
Offline 70 rtse
Need  fan shroud for a 22 inch radiator any one know where i can get 1 from.
check PM|  :bigsmile:
Offline JS27N0B
  • Member since Jan 28th 2003.
How much just for the top tank?
2013 Tige' RZR 343hp
Offline Total BS
  • '71 Carrabuda Baby!
I was just thinking something very similar.  To be able to use the top tank as a dummy overlay over an existing radiator. Hmmm :clueless: You get your stamped numbers and keep your existing radiator.
1971 'Cuda 383
1970 Chevelle SS LS6
1999 Durango
-New Joisey-
Unfortunately that question already arose. I was told they cannot be purchased seperately. But I can ask again. :)
Offline JS27N0B
:popcorn:
Offline 73Cuda73
I do have the mounts for a 26" radiator. How much will one be shipped to Colorado zip code 80909? Thank You
Offline protour7
BE AWARE YOU CAN GET AN ORIGIONAL WITH THE CORRECT NUMBERS FOR A LITTLE LESS THAN THIS GUYS PRICES, THEY LOOK CLOSE, BUT NOT EXACT SO IF YOU ARE GOING TO BOTHER PUTTING NUMBERS ON YOUR RAD. FOR POINTS YOU SHOULD STICK TO ORIGIONAL....$1400 FOR A REPRODUCTION RADIATOR, YOU ARE NUTS
