Author Topic: engine mounts  (Read 1869 times)
engine mounts
« on: May 13, 2006 - 02:01:52 AM »
I need the source for the true interlocking engine mounts , anyone have it ?
Offline matt63
Re: engine mounts
« Reply #1 on: May 16, 2006 - 08:45:06 PM »
I believe that Schumacher offers these.  They call them Magnum mounts.  http://www.engine-swaps.com/
If these aren't the right kind perhaps Imperial offers them although I wouldn't be surprised if they make them for Schumacher.
Matt in Edmonton
'68 Valiant
Re: engine mounts
« Reply #2 on: May 17, 2006 - 12:31:06 AM »
I guess that was obvious , Thanks Matt
 I have a customer that had a broken engine mount so the shop changed it & then playing with his car & trying to tune the 6 pack for some unknown reason they managed to rip the new mount apart & bend the fins in the converter so it wil not idle in gear now either
Offline Plum6Pak
  • Plum6Pak
Re: engine mounts
« Reply #3 on: May 17, 2006 - 06:43:47 AM »
Will this style of mount eliminate the need for a torque strap? I was going to go stock mounts and ad a torque strap but if these will do the trick and have the engine sitting in the exact stock location then maybe these would be better.
Re: engine mounts
« Reply #4 on: May 17, 2006 - 10:16:20 AM »
yes , this is why I was looking for them , there is a metal over lap inside the molded rubber to limit the m,ovement & stop the mount from tearing apart
Offline Plum6Pak
  • Plum6Pak
Re: engine mounts
« Reply #5 on: May 17, 2006 - 06:38:18 PM »
I just got off the phone with Schumacher and they have discontinued the Magnum mounts and are also out of of stock. They have a new version coming out sometime soon but didn't have a specific date. Sounds like they are even better than the old version. They will be poly with the interlock built in like the old ones. Hope it isn't too long waiting for these.
Offline firefighter3931
Re: engine mounts
« Reply #6 on: May 17, 2006 - 06:45:12 PM »
Make them yourself. I posted this over at the Charger board awhile back :
http://www.dodgecharger.com/forum/index.php/topic,13216.0.html
Ron
Ps. Sorry to hear about your friends converter  :swear:
68 Charger RT street/strip Bruiser & 70 Charger RT 440-6pack the ultimate Cruiser
Offline Plum6Pak
  • Plum6Pak
Re: engine mounts
« Reply #7 on: May 17, 2006 - 07:45:01 PM »
Ron
Now why didn't I think of that?? :clueless:
Not trying to hyjack this thread since Chryco originally asked the question but that is a great fix! Thanks for the info, going to do that to mine.  :thumbsup:
Re: engine mounts
« Reply #8 on: May 18, 2006 - 01:39:20 AM »
I was trying to figure ou thow to do that with affecting the way the  mount sits on the K frame
 Thanks Ron
Re: engine mounts
« Reply #9 on: May 18, 2006 - 08:34:05 AM »
You're welcome.  :wave: I'm sure this mod will fix the problem.  :thumbsup: Now about that converter.... :stomp:
Ron
