Author Topic: VIN locations  (Read 3479 times)
Offline mrbill426
    • All Around Mopars
VIN locations
« on: May 14, 2006 - 09:34:22 AM »
I have read many references to VINs being stamped on various body parts.  With regards to the radiator supports, where exactly should they be found?  The right side support in our car has been molested, it looks like it was for a smaller (22"?) radiator and was cut with a torch then a piece of a 26" support screwed over the top of it...weird!  The "22" support still wraps around and spot welded to the right fender shield.
The car has factory A/C, and I thought ALL A/C cars came with 26" radiators anyway.  The line code for the radiator on the build sheet is "26" which I thought was the rad size too.  I'm confused  :clueless:
 :working:
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
Offline Carlwalski
Re: VIN locations
« Reply #1 on: May 14, 2006 - 09:39:29 AM »
 :thumbsup:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline mrbill426
    • All Around Mopars
Re: VIN locations
« Reply #2 on: May 14, 2006 - 09:47:55 AM »
You are the MAN!   Thanks! :cheers:
I was looking at the side supports, not the yoke  :screwy:
On the transmission, I've been looking down along the pan rail.  Supposedly there are some sort of numbers on the block below the cylinder head, I see a couple numbers there but the rest is rusted off  :(
MOPAR or NO car!
Offline mrbill426
    • All Around Mopars
Re: VIN locations
« Reply #3 on: May 14, 2006 - 10:15:55 PM »
Well, I found all the numbers in the indicated palces EXCEPT on the radiator support.  The only number I found on it was on the passenger side, stamped upside-down and it does not look like a VIN, it has numbers and letters mixed.  :clueless:   All the other numbers match the VIN under the windshield.  Four out of five with one missing, is that okay?
 :working:
MOPAR or NO car!
Offline Robb
Re: VIN locations
« Reply #4 on: May 14, 2006 - 10:36:37 PM »
You know, thats where I used to look for a long time too, on the pan rail....  Ive seen a lot of references telling people to look there.  There ARE numbers there that decoded to the version of 727 for the car and motor combination, but no VIN.
That pic/scan is something to hold on to for sure.   :cheers:
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
Offline Robb
Re: VIN locations
« Reply #5 on: May 14, 2006 - 10:38:47 PM »
is there a yellow sticker or anything else possibly covering the top of the support ?     Ive heard of some stickers covering the numbers before.   :dunno:
Offline mrbill426
    • All Around Mopars
Re: VIN locations
« Reply #6 on: May 14, 2006 - 10:47:39 PM »
I will look some more, maybe I took the locations too literally?  It might be on top and not specifically in the right front upper corner?  The support is rusty in some places and has thick paint on others, maybe there is still hope in finding it.
Thanks  :thumbsup:
 :working:
MOPAR or NO car!
Offline Robb
Re: VIN locations
« Reply #7 on: May 14, 2006 - 11:01:22 PM »
I just went and looked at mine, and on my car the rad support numbers are on top of the Rail, and just to the drivers side of the hood spring about 4 inches or so and mine is covered by a yellow sticker (but the first letter is visible)........ and with a flashlight at the right angle I can read the rest of the numbers underneath as the sticker kinda light depresses into them.
good luck
Alaskan_TA
Re: VIN locations
« Reply #8 on: May 14, 2006 - 11:06:16 PM »
The radiator support number location can vary a lot. I have seen them from the center of the radiator support to clear over by the battery, sometimes on top and sometimes stamped in the engine bay side. I have seen them under the yellow coolant stickers too.
Happy hunting.  :cheers:
Barry
Offline mrbill426
    • All Around Mopars
Re: VIN locations
« Reply #9 on: June 08, 2006 - 11:45:59 PM »
Found it!  :bananasmi
Is in the back (engine) side of the radiator support yoke, upside-down, and near the upper edge near where it slopes downward.  Was under several coats of paint  ;D
Thanks for the help  :cheers:
 :working:
MOPAR or NO car!
