Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
Manual Steering Questions
« previous
next »
Print
Pages: [
1
Author
Topic: Manual Steering Questions (Read 1502 times)
Plum6Pak
Resident
Plum6Pak
on:
May 14, 2006 - 09:48:54 AM »
I've read where all the steering gears will fit from 65-78 A-B bodies.
I realize there are differences internally like ratios and externally like housing material (aluminum or cast iron). I don't want a quick ratio since I'm running a big block in my B body, anyone know if there are differences in the 6 cyl vs 8 cyl boxes?
There are articles stating that a 72 Dart 6 cyl will fit the 70 B body but fit isn't the only thing I am concerned with here. Will any gear box hold up in a B body big block? Just some things I'm considering, I would like manual steering if possible. Thanks!
Logged
72hemi
Resident
MEMBER SINCE JANUARY 2006
Re: Manual Steering Questions
Reply #1 on:
May 14, 2006 - 10:28:21 AM »
I've run six cylinder duster boxes on V8 cars and the only difference that I have found is the pitman arm needs to be changed.
Logged
1996 Dodge Viper GTS Coupe
Alaskan_TA
Guest
Reply #2 on:
May 14, 2006 - 05:22:46 PM »
I am not sure about all years, but boxes from 1969-71 A, B and E bodies are all the same. I have heard that they are the same from 1/2 ton pickups and vans as well? The manual box in my '67 Barracuda came from a '69 Road Runner, no problems.
Barry
Logged
Plum6Pak
Resident
Plum6Pak
Reply #3 on:
May 14, 2006 - 08:32:08 PM »
Thanks guys,
sounds like it won't be too big a deal to swap and probably not to expensive. Better start keeping an eye out for one.
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #4 on:
May 14, 2006 - 11:57:00 PM »
I have a spare if needed
Logged
360 'CUDA
Sr. Resident
Reply #5 on:
May 15, 2006 - 03:27:22 PM »
The one in my $32.00 motorhome sure looks the same. When I am done cutting it up I am gonna try to bolt it in one of my chassis
Logged
Plum6Pak
Resident
Plum6Pak
Reply #6 on:
May 15, 2006 - 03:59:09 PM »
$32.00 Motorhome!!? LMAO, if the steering gear fits, that's well worth the 32.00 you paid!
I'll be curious to see if it fits, if it does, that should be plenty heavy duty enough.
Chryco, I've got a lead on one from another member in California. Haven't heard back so I'll let you know how it pans out. Thanks!
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #7 on:
May 15, 2006 - 10:27:20 PM »
no prob
Logged
oldkimmer
Jr. Member
Reply #8 on:
October 31, 2006 - 09:51:59 PM »
6 cyl boxes are 6 turns lock to lock, V8s are 5 turns.
Logged
The beast has been unleashed........Thems the hazzards..........Unleash the beast......
Jacksboys
Sr. Resident
Here Since 08/28/06 GEORGIA
Reply #9 on:
October 31, 2006 - 10:22:03 PM »
Took one off of a 70 dart and it fit perfectly on my 71 Challenger. I even used the power steering pitman arm off the Challenger and everything fit perfectly.
Logged
1971 Dodge Challenger: 360/904/3.23
Plum6Pak
Resident
Plum6Pak
Reply #10 on:
November 01, 2006 - 05:02:12 AM »
Thanks guys, I still haven't done this and your imput is very much appreciated. Good information.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
