Author Topic: Cam Change Without Engine removal?????  (Read 839 times)
Offline woody9512
  • 71 Billboard Cuda, Pistol Grip 4-speed.
« on: May 14, 2006 - 10:56:17 AM »
    I have a 71 Cuda 340 and originally I had thought that I just needed a new Hyd lifter that made a faint ticking but when I pulled out the lifter I noticed it badly worn on the bottom and sorry to say also noticed that the cam lobe is also worn......so...I guess a cam change is also needed.
    My question is........how difficult is it to change the cam with the engine still in??  If I remove the rad will that give me enough room to pull the old cam out and guide the new one in or would the grill also have to be removed to get enough room???
Thanks  "Tim"
Re: Cam Change Without Engine removal?????
« Reply #1 on: May 14, 2006 - 10:59:06 AM »
you will have enough room just pulling the rad
Offline woody9512
« Reply #2 on: May 15, 2006 - 07:27:33 AM »
As usual Chryco................you da man!!!!!
Thanks   "Tim"
