Author Topic: Bolting the K frame to the chassis rails  (Read 1458 times)
Offline wart1de
    • Vivah
« on: May 14, 2006 - 05:49:26 PM »
When I pulled my K frame out of the car there was nothing between the K frame and the chassis rails. A picture I saw in a Plymouth service manual shows a bush or washer between the two. Now that i'm about to bolt it back in, can anyone tell me whether anything is meant to go between the two? Metal on metal doesn't seem right but thats how it was when I pulled it out.
1973 Plymouth 'Cuda
1980 Ford Falcon XD ESP
2012 Jeep Wrangler Rubicon
Offline jvike
  • Pro-Touring Cuda
Re: Bolting the K frame to the chassis rails
« Reply #1 on: May 14, 2006 - 06:44:43 PM »
Mine was also metal to metal, so that's the way I put it in.
« Reply #2 on: May 14, 2006 - 11:58:41 PM »
I have never found or used anything between the surfaces
Offline wart1de
    • Vivah
« Reply #3 on: May 15, 2006 - 04:57:29 AM »
Too easy. Thanks guys :)
1973 Plymouth 'Cuda
Offline ShelbyDogg
« Reply #4 on: May 15, 2006 - 08:59:34 AM »
The later model Chryslers used  big rubber donut looking things around the k-member for noise isulation.They also used the new style motor mounts.   E-bodies did not use either of them.
« Last Edit: May 15, 2006 - 09:16:08 AM by shelbydogg »
Offline 4Cruizn
  • HEMI FISH
« Reply #5 on: May 15, 2006 - 09:03:35 AM »
 :iagree:  I pulled mine a couple weeks ago and nothing was there so that's the way it's going back together!   :wave:
Offline mrbill426
    • All Around Mopars
« Reply #6 on: May 15, 2006 - 09:26:21 PM »
Hey, installing from the bottom...they way to go??
 :working:
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
Offline 360 'CUDA
« Reply #7 on: May 15, 2006 - 09:30:47 PM »
 :thumbsup:
On a full on restoration like yours yes...  I wouldn't do that just to change the bearings or something on a done car
Offline wart1de
    • Vivah
« Reply #8 on: May 15, 2006 - 09:31:51 PM »
I don't think it can go in from the top?  :drunk:
1973 Plymouth 'Cuda
Offline mrbill426
    • All Around Mopars
« Reply #9 on: May 15, 2006 - 09:33:58 PM »
Thanks, 360cuda, just might do that.  ;)
MOPAR or NO car!
« Reply #10 on: May 15, 2006 - 10:34:12 PM »
if you install from the bottom virtually everything can already be on the engine , starter , headers steerring box & power steering hoses pulleys fanbelts  etc can all be hooked up
Offline mrbill426
    • All Around Mopars
« Reply #11 on: May 16, 2006 - 08:34:40 AM »
Cool deal, thanks!  :cooldancing:
MOPAR or NO car!
