When my clutch pedal is up, my bearing is not touching the PP fingers. There is a TINY air gap between the bearing and fingers. The way I had to get that setup: 1, Had to make sure throwout bearing clips are tight on clutch fork. 2, Had to make sure clutch fork is very tight on bellhousing pivot. 3, have to have 4 good nylon bushings and grease in Z-bar.
If all this is good, pressure plate should push clutch pedal back up till over-center spring pulls pedal the rest of the way.
Send me a round trip ticket from St. Louis and I'll fix it for you in 30 minutes and $50.
