Author Topic: 4 spd linkage question  (Read 5430 times)
Offline ShelbyDogg
Re: 4 spd linkage question
« Reply #15 on: June 14, 2006 - 10:30:12 PM »
If the clip is loose on the fork, yes it can make a big difference. The spring on the fork to bellhousing is pulling the fork AGAINST the clutch.  If the clip is tight, the spring is pulling fork AWAY from the clutch
If your clip is loose, cut off 2 rivets holding clip to fork using Dremel tool with High speed cut-off wheels.  Bend clip so it is straight. Drill the 2 holes to accept Tiny bolts and locknuts. Reassemble clip on fork with small wrenches.  The clip should hold the fork very tight against the pivot clip.
Offline madness
« Reply #16 on: June 15, 2006 - 05:52:50 PM »
thank u dogg for the info the fork clip is rusted pitted looks like if i try to bend it will break have one orderd from brewers that will really surprise me if it makes that much diff everything i got from tonys is junk has been replaced first time i talked to him on the phone i could see hes a clown
Offline ShelbyDogg
« Reply #17 on: June 15, 2006 - 10:19:16 PM »
You should get a new Z-Bar since yours was cut and rewelded many times.
Offline madness
« Reply #18 on: June 15, 2006 - 10:36:25 PM »
its on the way also
Offline madness
« Reply #19 on: June 16, 2006 - 10:38:41 PM »
hay dogg i had sometime in the shop so i grinded the rivits off the fork bent the keeper need to get the screws with nylocks it looks like someone bent the keeper now my question is can i get this fork back on with out pulling the trans and not bending the keeper it came out with out pulling the trans.do you grease the shaft the TO slides on
Offline ShelbyDogg
« Reply #20 on: June 16, 2006 - 10:50:59 PM »
Madness,
It is so hard to put that fork back in with the trans in. You can try to do it but you might bend the clip again.   If you can get it on, great! If you have a rolling trans jack, it would be easy to slide it back halfway.
The new throwout bearing holders have some grease in the groove.  I put a little in there if it is dry. I also put a little grease on the fork at the pivot.
Good Luck.
Offline madness
« Reply #21 on: June 27, 2006 - 09:57:58 PM »
hopeing to solve this thing soon put in the new parts z bar fork no inprovement or little new fork fitted no tighter then the old z bar seems better bends where they need to be brewers is a good parts store this brings me to the pedals 70-74 where the same thats what i have i can only find one photo of assembly my ov center spring is on diffrent short side hooked to pedal arm can this make a diff its a spring eather ways not a fun job to turn around guess its the only thing left
Offline madness
« Reply #22 on: June 28, 2006 - 06:28:24 PM »
thanks for the reply the TO is new fits and works fine i have had the pedals out many times the short ends hooked to the pedal the book i have shows it should be the long end better get to work
Offline ShelbyDogg
« Reply #23 on: June 28, 2006 - 11:05:03 PM »
Here is a picture of the spring. It has the short end on the pedal and will only fit one way.  This is how it should look.
Offline madness
« Reply #24 on: June 29, 2006 - 07:18:05 PM »
thank u shelby thats how mine is now glad i didnt take it out this book throws me off it shows it the other ways when i put it in i thought it can only go one ways now i need to start the car to see if the TO is spinning with clutch out
Offline 70challengerrt
« Reply #25 on: June 29, 2006 - 08:07:13 PM »
What does the over center spring do anyway? I never installed mine. Should I?
Offline ShelbyDogg
« Reply #26 on: June 29, 2006 - 11:12:58 PM »
70ChallengerRT, that spring helps you push the borg&beck style pressure plates in and also helps return the pedal to the up position so that the throw-out bearing isn't constantly touching the clutch fingers till you push in the clutch.  If your bearing always touched the release fingers it would wear out sooner than later, start making noise, then the trans has to be pulled to replace it.  This is the problem Madness has. His clutch fork isn't pushing his pedal back far enough for the over center spring to take over and pull the throw out bearing off of the fingers. Some people take them out when they install a diapham style pressure plate because the big spring is too strong to allow the clutch to release. They should put a lighter spring somewhere back in the linkage to pull the bearing back.
Madness, My clutch pedal pulls itself up very strongly when the linkage is unhooked since I pulled the pedals off and greased up all of the pivots. Are yours swinging freely and greased up?
Offline madness
« Reply #27 on: June 30, 2006 - 08:08:59 PM »
with the linkage unhooked about half ways  or less it pulls the pedal down vary hard do not get ur hand in the ways mouse trap x 100
Offline madness
« Reply #28 on: June 30, 2006 - 08:19:36 PM »
i read mclouds instructions agein it says 1/8 -1/4 on the bearing if i put it there im sure it would grind the gears and does not cumm back enough for the ov center to return all the ways the bearing is not tight on pressure plate u can easly turn it with ur fingure maybe this is as good as it gets i started it up can see the bearing spinning maybe that does not mean anything its not tight just seems like there should be more ajustment i will not cut up another z bar pedal are lubed well did that before install all the parts are where they should be and workin right except the ajustment
Offline ShelbyDogg
« Reply #29 on: June 30, 2006 - 09:08:45 PM »
1/8 to 1/4 inch of gap?  No way.  My pedal would not pull up all the way if I put that much gap between the bearing and the fingers.  Adjust the nut till the bearing comes off of the fingers by a couple of thousands, till the bearing stops spinning with your foot off of the clutch. If the car isn't running, put your hand up inside the bellhousing and spin the bearing with your finger. Loosen the nut till the bearing no longer touches the fingers. A veri small gap is all that is needed. Now when you push in the clutch pedal with your hand, you will feel about 1/2" of play before it gets harder to push.
