Author Topic: update EvilTwin's Challenger project!  (Read 48378 times)
Offline EvilTwinATX
Re: update EvilTwin's Challenger project!
« Reply #105 on: February 26, 2008 - 08:28:48 PM »
Those look great!!!!!! I need to do mine in white. Was is hard to do?
It was surprisely easy to do actually. I assumed it was rocket science or something but it wasn't. You absolutely need a GOOD set of hog-ring pliers, 3/4''-1'' hog-rings (anything smaller would make it nearly impossible), and a little determination. I used the write-up done by Cody on LAMOPAR.COM as reference... it was very accurate and well-done.
Beats the $400 the local upholstery shops wanted to charge me.. that seemed ridiculous!
Offline IMNCARN82
  • LeDZeP
« Reply #106 on: February 26, 2008 - 08:38:11 PM »
yup - when I stripped mine I found the bezels had a pretty good microfinish on them. I polished them anyway then clearcoated to make sure they wouldn't dull from oxidation. The polished bezels do make the dash pop!
I want mine like this. Looks real nice. So...The factory guages are polishable? :clueless:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline EvilTwinATX
« Reply #107 on: February 26, 2008 - 09:05:19 PM »
its just aluminum... should be no problem polishing.. I did mine by hand. The only think you have to worry about is oxidation... I plan in using Zoops to seal it and keep it looking nice.
I wasn't all that easy though! The factory paint is really hard to get off and I didnt want to strip off the factory coating that prevents rusting... so I did just the bezel, by hand!! It was long and tedious. I almost messed it up a couple of times.
I used pinstriping tape to mask it all off before painting.
If I ever try to do this again I would use a rallye bezel that is already messed up or the paint is messed up. If you plan to keep the wood grain on the rest of the bezel you WILL mess it up. I planned on painting my with textured paint so it was easier to hide the imperfections.
Good luck!
Offline miketyler
    • www.miketyler.net
« Reply #108 on: February 26, 2008 - 09:35:36 PM »
My bezels stripped pretty easy. It might take a second application and you may have to fight the urge to take a razor blade to any stubborn remaining specks. You will destroy your factory graining in the process. When its done it does look pretty shweet!  :thumbsup:
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline Travis72
« Reply #109 on: February 26, 2008 - 11:35:57 PM »
Nice work!
Travis
72 Cuda
Offline EvilTwinATX
« Reply #110 on: April 08, 2008 - 07:21:35 PM »
Centerlines mounted and Wilwood Big Brake Setup going on!  :clapping: :drunk:
Offline CHUCKS71
  • "IF YOUR NOT FIRST YOUR LAST"
« Reply #111 on: April 08, 2008 - 07:31:01 PM »
I dont have any good quality pics of the entire dash... the lighting was bad. Here is what I have..
Where did you get the silver guage faces? They look great!  :2thumbs:
:burnout::22yikes::burnout:    www.ronpaul2008.com
71 Challenger 4spd   www.conservativepunk.com
03 Ram diesel 6spd    http://s105.photobucket.com/albums/m222/chucknutz/1971%20Challenger/
Offline NoMope Greg
« Reply #112 on: April 08, 2008 - 07:35:46 PM »
Love, Love, LOVE that color!!  Beautiful!
Greg
2003 Ford Escape XLS
Currently Mopar-less :(
Offline Travis72
« Reply #113 on: April 08, 2008 - 07:45:49 PM »
Looks sweet!!!  The black finished rotors look cool too, however it will wear off just like the zinc wash right?
For the rear brakes you have to use the green bearings with those right?
Travis
72 Cuda
« Reply #114 on: April 08, 2008 - 07:50:26 PM »
Yowsir.....good lookin sguff ya got there....... What's the black on the brake rotors?
Offline EvilTwinATX
« Reply #115 on: April 09, 2008 - 12:39:52 AM »
Chuck.. the silver guage faces are custom.. I had them made based on my design for the car. I got them from WhiteGauges.Net... If you choose to go with a silk screen restoration you should be able to choose any color. I might redo the gauges using silk screening later on...
Everyone else.. the black coating on the rotors is to prevent rusting on the non-contact surfaces and keep them looking nice... the pad surface should wear off with the first use. Yes.. I have to use the green bearings.
Offline EvilTwinATX
« Reply #116 on: April 10, 2008 - 02:22:54 AM »
I had these made... they are so purdy!!!
Offline ntstlgl1970
  • T a c o c a t
« Reply #117 on: April 10, 2008 - 02:30:18 AM »
Door latch strikers? I take it those are in stainless? those look nice!
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #118 on: April 10, 2008 - 10:52:39 AM »
WOW!  :o  Those are nice!
If I put those on my car it'll make the reast of my car look even more like crap!  :roflsmiley:  :smilielol:
Offline EvilTwinATX
« Reply #119 on: April 10, 2008 - 11:41:38 AM »
YOU BOTH NEED A SET!! ....  :poopoke: :poopoke:
