Author Topic: Power brakes very grabby  (Read 989 times)
Offline MyMopar
« on: May 19, 2006 - 01:34:53 PM »
I'm still waiting on my manual to come in but I have this question that has been bothering me.  The brakes on my 73 Challenger are WAY to touchy.  I can get whiplash driving and stopping.
Power brakes, discs in front, drums in rear.
I adjusted the rear drums and that was about all for now.  What can cause such a condition.  Is the brake booster "overboosting" and cause a spike in pedal pressure whn I apply the brakes.  I am talking lightly foot on the pedal and 4 wheel lock.
1969 (OO===]|[===OO)
1973 (OO/=====\OO) <---SOLD
1997 (O|||||O) <---SOLD
Smoke tires, not drugs!
Re: Power brakes very grabby
« Reply #1 on: May 19, 2006 - 02:02:18 PM »
if the pads or shoes are contaminated with oil they can get very touchy
Offline ShelbyDogg
« Reply #2 on: May 20, 2006 - 10:25:09 PM »
Make sure that your brakes are clean like Chryco suggested first.  If they are clean, unbolt the 4 bolts holding the master cylinder to the booster. Pull it away far enough to adjust the pushrod coming out of the booster. Try adjusting it IN a little at a time to see if the problem changes.  I'm thinking that the booster isn't letting the master cylinder get back to the release position.
Offline MyMopar
« Reply #3 on: May 23, 2006 - 08:01:27 AM »
Why would oil/grease make the brakes touchy, I'd think just the opposite would be true.  Do teh pads absorb the oil and swell?
Offline ShelbyDogg
« Reply #4 on: May 23, 2006 - 08:13:32 AM »
The Moisture does not let them slip and tighten up with heat.   Like a fireman trying to slide down the pole with a wet sweaty skin, too sticky.
Offline MyMopar
« Reply #5 on: May 23, 2006 - 02:12:07 PM »
I understand now, but you could have used a better analogy   :eek7: :eek4: :puke:
Offline ShelbyDogg
« Reply #6 on: May 23, 2006 - 03:21:37 PM »
I couldn't think of anything else at the time that doesn't slip and slide better with lube, without getting nasty.
