Author Topic: feel like an idiot  (Read 1847 times)
Offline moparclown
feel like an idiot
« on: May 19, 2006 - 08:20:18 PM »
what i have is a 360 with a cast crank and i thought that my 318 lower pulley would bolt up.now i know that the pulley would only bolt up one way on the 318,but it doesn't fit the 360.the 318 had ac so its a 3 groove pulley and all i have right now.my question is do i need to find a 360 pulley?or will a 2 groove 340 pulley work?
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
Re: feel like an idiot
« Reply #1 on: May 20, 2006 - 09:34:53 PM »
Heck if I know...but 74 people have read this post without an answer...so don't feel like an idiot!  :roflsmiley:
« Reply #2 on: May 20, 2006 - 10:17:07 PM »
I think I have a extra 340 pulley, can you provide measurements of what you need?  :bigshades:
Offline madness
« Reply #3 on: May 20, 2006 - 11:18:21 PM »
the pulley should fit if not go to the junk yard and start pulling pullys
« Reply #4 on: May 21, 2006 - 12:05:24 AM »
due to external balancing on the 360 the  balancer is thicker so the pulley is shallower , hit the wrecker & get a set of pulleys off a 360 LA engine
Offline moparclown
« Reply #5 on: May 21, 2006 - 03:54:39 AM »
yesterday i got the 2 groove pulley right off a 340 and guess what that doesn't fit either.i went to the local salvage yard and they only had the 3 groove pulley.I think ma mopar might have changed the bolt pattern on the 360 engines dampner.
Offline tactransman
« Reply #6 on: May 21, 2006 - 05:48:30 AM »
Does it not work because of belt alignment or bolt hole alignment? I went from a 318 to a 360 in my '73 challenger and if I remember correctly I had to file one bolt hole out.
Terry-tactransman
Union, Mo.
Offline moparclown
« Reply #7 on: May 21, 2006 - 09:56:49 AM »
the belts line up is fine its the bolt hole pattern,might have to order a pulley.just read in one of my mopar books that the bolt pattern is different for the cast crank engines after 73.
« Reply #8 on: May 21, 2006 - 09:58:22 AM »
1 hole was moved , , I have filed that hole to use the pulley with no issues
Offline tactransman
« Reply #9 on: May 21, 2006 - 01:03:41 PM »
:iagree: Yes that is what I did.
Terry-tactransman
Union, Mo.
Offline TreeFrog
    • TreeFrog
« Reply #10 on: May 22, 2006 - 08:27:05 AM »
I knew a guy that used to move holes for a living....odd job but paid well...
 :faint:
87 Dodge Ram     318 Blue
88 Dodge Ram     360 Grey (+)
Offline ShelbyDogg
« Reply #11 on: May 22, 2006 - 09:58:17 AM »
I read the same thing in a Mopar book years ago.  They also said to File the one hole to use the pulley.
