Author Topic: Aftermarket 727 selection  (Read 12121 times)
Offline cudagirl4406pk
  • Yes i am a Girl and No you cant drive my CUDA
    • Garageartmusclecars
Re: Aftermarket 727 selection
« Reply #15 on: May 20, 2006 - 11:30:15 PM »
NO core charge and it was $85 shipping.
Yes i am a girl and no you cant drive my MOPAR :)
Offline MyMopar
« Reply #16 on: May 24, 2006 - 08:32:23 AM »
I have a TCI and I will say that it is below par.  I guess mine was made on a Monday or Friday?  Leaked fluid first time I installed it, replaced the front pump seal twice and the rear tailshaft seal once.  Unfortunately I'll have to stick with this piece of junk until something happens or I can get a good rebuild on it for under $500.  Perhaps this winters project  :dunno:
1969 (OO===]|[===OO)
1973 (OO/=====\OO) <---SOLD
1997 (O|||||O) <---SOLD
Smoke tires, not drugs!
« Reply #17 on: May 24, 2006 - 08:35:41 AM »
tractransman basic rebuild is $350 w/core & he's ofering discount to CC.C.  :sleeping:
Offline RD
    • KANSAS MOPAR CRUISE
« Reply #18 on: May 25, 2006 - 11:42:27 PM »
hello,
CRT is good, as well as A and A trans.  John gets much of his hardware components from A and A trans.
I do rebuild on the side also, but I will not try to promote my wares here since tactrans is a well respected member on this board.  I have built a trans that has lasted 7 years of abuse behind a 3850lb 71 Charger running 12.17's.  I didnt use a special rebuild kit, and all I had was a shift kit.
727's are very strong up to 500hp applications.  Up until that hp rating, it is suggested (I suggest too) to put in such components as bolt-in sprag as a minimum for safety measures.  After 500hp its mandatory in my opinion or you run the risk of blowing your leg off.
And to answer your initial question, I prefer my own transmissions.  :naughty:
« Last Edit: May 25, 2006 - 11:44:44 PM by RD »
Eskridge, Kansas (32 Miles SW of Topeka, KS)
Offline tactransman
« Reply #19 on: May 26, 2006 - 12:30:20 PM »
John Vinson at JVX http://jvxracing.com/ is very good also. I have talked to him many times and we are definitely on the same page. He sells the forward pattern manual (low band apply) valve body that I highly recommend. If you use a low band apply valve body you do not  need a bolt in sprag. :thumbsup:
« Last Edit: May 26, 2006 - 12:37:52 PM by tactransman »
Terry-tactransman
Union, Mo.
Offline RD
« Reply #20 on: May 26, 2006 - 04:49:25 PM »
thats a true statement on the low band apply.  I was just stating that a bolt-in sprag would be recommended as a safety precaution.  Though I have not specifically seen a regular sprag come unglued, I have heard about sprag failures with low band apply valve bodies.  The likelihood of it happening is not really that high, I grant you that, but I would rather have the added insurance of knowing that it is there to protect me than not.
Very good input tactrans, I am sure you help develop a lot of informed consumers on this board and that is the major reason why we are here.  :thumbsup:
Offline 73Cuda73
« Reply #21 on: May 30, 2006 - 07:14:27 PM »
Hey tactransman,
 I have a 73 Cuda and I am currently having my 440 engine rebuilt. The car does not have a tranny so I am in the market for one. The plans that I have for the car is a high powered 440 but still streetable. Any suggestions would be greatly appreciated. Could you also include shipping prices to Colorado zip code 80909?
Offline 727specialist
« Reply #22 on: May 30, 2006 - 08:29:16 PM »
 ********************727 SPECIALIST******************
Keith long 219-838-1251 or 219-718-3542
Email kfl727specialist@peoplepc.com
REBUILT 727 904 TORQUEFLITE TRANSMISSION FOR SALE
*Hd 727 Big or Small Block $600.00
*904 273-173 Ratio Gears $600.00
*Std 904 $500.00
*Std 904 Slant Six $500.00
Due to the higher cost of cores
price going up on this trans soon
Cable shift - pushbutton trans
Big Block slip yoke type
completly rebuilt $1000.00
ALL ABOVE TRANSMISSIONS BUILT AND READY FOR PICKUP OR SHIPPING
REBUILDABILE CORES FOR YOUR
CHRYSLER DODGE OR PLYMOUTH
WILL ONLY SELL REBUILT
727 BIG BLOCK WITH LOCKUP CONVERTOR
727 SMALL BLOCK WITH LOCKUP CONVERTOR
727 SMALL BLOCK - THE THING TRANSMISSION
904 WITH LOCKUP CONVERTOR
4WD 727 SMALL BLOCK
4WD 727 BIGBLOCK
BIG BLOCK MOTOR HOME TRANS WITH BRAKE ON REAR
66 & OLDER POLYSPHERE TRANS
62/64 BIG BLOCK PUSH BUTTON TRANS
62/64 SMALL BLOCK PUSH BUTTON TRANS
62/64 904 PUSH BUTTON TRANS
62/64 SLANT SIX PUSH BUTTON TRANS
*Race Trans Brake Big or Small Block $1.600.00
*Race Reverse Manual Big or Small Block $1250.00
*727 with gear venders od unit installed 3200.00
Parts For Sale
Griner Trans Brake
Band On Valve Body $650.00
Griner Reverse Manual
Band On Valve Body$220.00
727 Kevlar ft band $30.00
727 Kevlar rear band $30.00
Buy the pair $50.00
727 Bolt in overrunning clutch/sprag $90.00
Stock rebuilt convertor
11 in high stall $150.00
***************Can also build to suit your needs***
*************************Restoration Street DragRacing
*********************************All transmissions rebuilt with MOPAR parts
**************************************Keep your Mopar all Mopar!!!!!
*************Ready to ship anywhere in the U.S.***
Northwest Indiana 3 miles from Illinois
Offline 73Cuda73
« Reply #23 on: May 31, 2006 - 03:07:39 PM »
What would you recommned for my application? What would my total price be including shipping to Colorado?
Offline tactransman
« Reply #24 on: May 31, 2006 - 03:15:24 PM »
How do you want it set up? Manual valvebody? ,reverse pattern or forward pattern ? Is it going to be on the street most of the time or the strip.? How much estimated H.P.?
Terry-tactransman
Union, Mo.
Offline 73Cuda73
« Reply #25 on: May 31, 2006 - 03:20:09 PM »
I am in your hands. What would you reccomend? The car will be 90% on the street and 10% on the strip. We are planning around 500HP.
Offline tactransman
« Reply #26 on: May 31, 2006 - 03:32:35 PM »
727 High Performance Prices
 Tax or any special shipping
(where applicable) are not included
Basic Rebuild w/core (no converter)
$350  *Core charge of $100 if no core supplied*
3.8 Intermediate lever
$39.95
Mopar Deep Pan
$75.00
5 Clutch Third Gear Clutch Pack
$69.95
Forward Manual ValveBody
$225
Sonnax Billet Aluminum Rear Servo
$39.95
Plus shipping , that I would have to find out.
I recommend you order a converter from Coan http://www.coanracing.com/Catalog.asp?CatClass=04CO
There will be a CC.com member discount also not applied yet. :cheers:This Transmission will handle about 700 H.P.
« Last Edit: June 02, 2006 - 08:48:48 PM by tactransman »
Terry-tactransman
Union, Mo.
Offline 73Cuda73
« Reply #27 on: May 31, 2006 - 04:19:44 PM »
Do you also carry driveshafts and tranny mounts?
Offline tactransman
« Reply #28 on: May 31, 2006 - 04:23:06 PM »
No driveshafts , yes on tranny mounts. Mancini Racing has a nice cut to fit driveshaft kit.
http://chucker54.stores.yahoo.net/driveshaftkits1.html
« Last Edit: May 31, 2006 - 04:25:20 PM by tactransman »
Terry-tactransman
Union, Mo.
Offline 73Cuda73
« Reply #29 on: May 31, 2006 - 04:41:55 PM »
Great! Would you mind checking into the shipping to Colorado zip code 80909? I would be interested in the tranny setup that you listed and a tranny mount. Once you find a shipping price please give me a total. I do not have a core. I will check with Mancini on the driveshat kit. Anything else that I should check into?
