Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
BRAKE BOOSTER VACUM LINE
« previous
next »
Print
Pages: [
1
Author
Topic: BRAKE BOOSTER VACUM LINE (Read 1246 times)
justin16440
Jr. Member
on:
May 21, 2006 - 06:34:51 AM »
Has anyone drilled a hole in there Holey SD manifold for a brake booster vacum line I used the one on my mighty Demon for the pcv valve .
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: BRAKE BOOSTER VACUM LINE
Reply #1 on:
May 21, 2006 - 09:56:05 AM »
actually you can hook into the Egr plate at the rear of the SD , it has manifold vacuum at 1 of the ports
Logged
justin16440
Jr. Member
Reply #2 on:
May 21, 2006 - 11:18:40 AM »
thanks, you said one of the ports does it matter which one of the 3
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
May 21, 2006 - 11:26:13 AM »
yes , you wil have to remove the plug & see which one has the vacuum
Logged
justin16440
Jr. Member
Reply #4 on:
May 21, 2006 - 11:36:19 AM »
Thanks
Logged
justin16440
Jr. Member
Reply #5 on:
May 21, 2006 - 12:48:39 PM »
Can I put a T where the carbs vacuum port is and run both the pvc and the brake booster line off of that?
Logged
Bullitt-
Permanent Resident
Better Things To Come Member Since 2/16/06
Reply #6 on:
May 21, 2006 - 03:31:02 PM »
my best knowledge is that you wamt Manifold Vacume for brakes, not carb. vac.
Logged
Wade 73 Rallye 340..'77 Millennium Falcon...13 R/T Classic
Huntsville, AL
Chryco Psycho
Administrator
C-C.com Guru
Reply #7 on:
May 21, 2006 - 11:23:09 PM »
not a good plan , the pcv has a constant leak & will weaken the vacuum in the booster for the brakes , it is better to have a dedicated line to the booster
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
