Hey guys,
This is my first post, Im from Australia (Melbourne) and Im looking to buy my first Mopar, a 74 Barracuda, 318, 727 column shift with allegedly matching numbers, in need of a full resto.
I have the VIN and have decoded it and it checks out as expected. It is: BH23G4B136024
My main concern with buying this car is that the fender tag has apparently "corroded away" although the edges are still "screwed on" according to the seller.
I have search through the past topics but was unable to find any reference to this problem. Apologies if you've dealt with it before.
So my questions for you guys are:
- Are there any factory or club records which would allow you to trace what options your car had in the abscence of a fender tag?
- Are fender tags and ID plates worth anything, ie could they be removed and used to rebirth a car as a higher spec model?
(I dont want to do this, i was just wondering if it was possible and if there are any low lifes out there who do it, as it is a problem with some big dollar Aussie muscle cars)
- Will a missing fender tag severvely drop the price of the restored car, considering that this is only a base model barracuda really and the engine type and number can be verified without this tag?
- Any other hints or information that i should ask the seller for to check out this car?
You should keep in mind that i havent seen the car in person yet, so am negotiating via email, as it is located about 3000 miles away on the other side of our big country.
Cheers,
