Author Topic: 71 cuda bumper brackets?????  (Read 6719 times)
Offline mrbill426
    • All Around Mopars
Re: 71 cuda bumper brackets?????
« Reply #15 on: September 12, 2007 - 02:19:30 AM »
I'm going to try for a better profile shot.   :picture:
If it IS a Challenger bumper I'll have to send it back  :banghead:
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
Offline mrbill426
    • All Around Mopars
« Reply #16 on: September 12, 2007 - 02:54:03 AM »
Okay, sorry for all the photos but here they are side by side and as close to being on the same plain as I could support  them.  They were rightside up and and fairly level.
MOPAR or NO car!
Offline purple1
  • Worlds first e-body trailer. Member since 3/10/05
« Reply #17 on: September 12, 2007 - 09:11:54 AM »
Sorry to say but that rechromed bumper looks like a 73-74 Challenger front bumper.
Dave :wave:
Worlds first e-body trailer.    Severna Park, Maryland
Offline IMNCARN82
  • LeDZeP
« Reply #18 on: September 12, 2007 - 10:24:24 AM »
 :banghead:  We'll that's part of the problem :pullinghair:
71' Demon
75' Duster
87' Conquest TSI
56' Plaza
Boulder CO
Robert    "cuda bob"
Offline toomanyprojects
« Reply #19 on: September 12, 2007 - 10:09:05 PM »
FYI-
1970 to early build 1972(before build date 01-1972) have all the same bumper brackets-
my friend's 73 that was built 09-1972-has the extended brackets-(pics to come)-
triplets(who worked at the L.A plant) said that they used what ever left over parts from previous years unless it was federally mandated (lower compression engines in 01-1972, and 5 mph bumpers in 01-1973) - they had a gray area or grace period before the Official recognized new year started-
my cars were built as follows;
02/1970 realy doesn't matter - only a clean 318 barracuda
10/1970 but a 1971 model year - numbers matching 340 w/engine cast of 8/1970 - high compression
09/1971 but a 1972 model year - numbers matching 340 w/engine cast of 9/1971 - forged crank - slight dish in piston
look closely @ attached pics-i can swap any brackets to any bumpers on these 3 cars-
i purchased the 1971 and 1972 from the original owners(the 71  is still in his name on the small california "PINK" slip)
the 1970 was purchased from a good family friend which was bought from the original owners-
i have owned all 3 vehicles for well over 17 yrs-
Offline mrbill426
    • All Around Mopars
« Reply #20 on: September 12, 2007 - 10:34:41 PM »
Thanks for the pics.  So, the red 'Cuda has the jack slots ('72-'74) but mounts to earlier brackets with all 4 bolts in front.  To use my existing brackets that's the style bumper I need.  Mine has an April '72 build date, all numbers matching 340 with a forged crank.
It is a bit of an odd fish though, all my research tells me my factory A/C car should have come with a 26" radiator however the original 22" radiator support was cut (with a torch) at a later date and a correct "26 inch one installed.  The body shop chopped a right side one out of a donor car, overlapped it over what was left of the spot-welded in original one, and held it in with 2 phillips head crews  :screwy:   I thought that maybe after it was (obviously) wrecked they had to replace the front end yoke and could only find one form a non-A/C car, but the yoke is original with a matching VIN. :dunno:
MOPAR or NO car!
« Reply #21 on: September 12, 2007 - 11:11:41 PM »
do you have pics tag, block#, and build sheet?
check fender tag and engine #-
a/c should be noted on fender tag-
340 early build date should come with forged crank--again check the #-and was the engine ever rebuilt?
because there was a time lazy mechanics would cut the radiator support to remove the engine forward(like in a van)and mickey mouse a new support from a donor car - instead of removing the hood-which usually takes 2 people-put preferably 3-
by cutting the radiator support, you can do it by yourself-
like i said earlier-check fender tag/build sheet(if available), and engine /trans #s-just to be thorough-
Offline mrbill426
    • All Around Mopars
« Reply #22 on: September 13, 2007 - 03:33:38 AM »
I have two matching build sheets and the fender tags, all indicate the car has A/C.  All the serial numbers match including the transmission.  I guess my parts book is wrong and there were factory A/C '72s  with 22" radiators.  Hell of a sloppy job putting in the larger one though  :eek4:  Right now I am in the middle of replacing both inner fender shields since they are badly rusted under the battery try, at both hood hindge mounts, and on the flat areas where the fender supports spot weld to them.  I also have new right side radiator support to replace that abortion that was left behind.
MOPAR or NO car!
« Reply #23 on: September 13, 2007 - 08:30:13 PM »
mrbill426-
at least you have everything- :jumping:
do you have any pics? :swaying:
Offline mrbill426
    • All Around Mopars
« Reply #24 on: September 15, 2007 - 10:55:20 PM »
mrbill426-
Here are a couple pics showing the rather interesting modification to fit the "26 radiator.  First shot shows how they torched out the right (22") support to enlarge the opening (real classy).  The second shot shows how they screwed on a donor piece from another car, right over the original one.  It's just plain strange, this car should have had a 26" radiator to begin with.
MOPAR or NO car!
Offline FM3V6M
  • TX9 383 4spd
    • mytx9cuda
« Reply #25 on: September 16, 2007 - 12:03:23 AM »
Hey toomanyprojects, are you in San Gabriel Valley, that neiborhood looks familiar!
« Reply #26 on: September 17, 2007 - 08:42:34 PM »
yup-
rosemead, Ca-
