Author Topic: Question about car height  (Read 1134 times)
Offline dlrogers
  • 1971 Challenger 383
« on: May 22, 2006 - 02:38:11 AM »
Hi all
I noticed that the height of my chally at the front end differs from side to side in that the left front is about 2cm lower than the right - the left front fender covers about 2cm more of the tyre than the other side so it's not tyre pressure. I don't think its the shocks in the front but was wondering if the torsion bars may be affecting things?? Any thoughts??
David
Bay of Islands, New Zealand
Re: Question about car height
« Reply #1 on: May 22, 2006 - 03:20:58 AM »
Yep,
  If it isn't a shock crapping out on you, then I would guess it's a torsion bar needing adjustment. I guess you need to decide if you want to lower one side, or raise the other.
Offline dlrogers
« Reply #2 on: May 22, 2006 - 04:29:41 AM »
Yea, thanks Mike, thats about what I thought.
David
Offline ShelbyDogg
« Reply #3 on: May 22, 2006 - 08:49:33 AM »
Make sure that your rear springs are causing it to look that way.    In my race car, I would preload right side rear so the car would lean left.  To compensate I would adjust the left front to make it sit level again.
To eliminate the rear suspension, you can use a 4x4 going across the rear frame, then jack it up right in the center. Then you can adjust the torsion bars to equal them out.
« Last Edit: May 22, 2006 - 08:51:38 AM by shelbydogg »
Oldschool
« Reply #4 on: May 22, 2006 - 04:18:52 PM »
After you get em evened back out, don't forget to have the alignment re-checked......   :grinyes:
« Reply #5 on: May 22, 2006 - 10:57:47 PM »
or check it with a tape measure
Offline dlrogers
« Reply #6 on: May 23, 2006 - 01:16:32 AM »
Thanks for the advice everyone
David
« Reply #7 on: May 23, 2006 - 12:30:42 PM »
make sure you take the weight off the front end of the car before adjusting the T bars
