Came across this problem tonight
Author Topic: Came across this problem tonight  (Read 947 times)
Offline Mike71Cuda
« on: May 22, 2006 - 07:35:39 PM »
While trying to install new Hemi. ON steering column where roll pin ghoes through knuckle on pump. Tangs that hold dust shield and boot on knuckle are worn out. ALso boot is shot. Where can I get a replacement knuckle and new boot?
Thanks
Smitty
Offline Killer_Mopar
Re: Came across this problem tonight
« Reply #1 on: May 22, 2006 - 07:44:35 PM »
I bought mine from steer & gear, but there are a couple other places that sell it. The seal really doesn't do a good job of keeping the dust out of the grease and the grease is too thick to come out when turning, so you could probably leave it like it is....however, it isnt that hard of a job so I would just replace it.
Offline Mike71Cuda
« Reply #2 on: May 22, 2006 - 08:54:03 PM »
Is ther eany reason to worry about it hampering the steering? What is worst case without fixing?
Offline 1BADFISH™
« Reply #3 on: May 22, 2006 - 08:55:39 PM »
I just bought a rebuild kit from local dealer for $14.
Charlottetown, PE
2014 GMC Sierra Crew Cab White Diamond edition.
1970 Dodge Challenger 340-6 4spd.
*Member Since* Oct 11, 2005
Offline ShelbyDogg
« Reply #4 on: May 22, 2006 - 11:36:42 PM »
If you don't replace that seal and cover, dirt and water will mx with your grease.
Offline Cuda Cody
  • Vancouver, WA
