Author Topic: Any Young Guns out there?  (Read 6271 times)
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
Re: Any Young Guns out there?
« Reply #15 on: May 04, 2002 - 10:38:36 AM »
Thanks SemiHemi. Here's a pic...
« Last Edit: December 31, 1969 - 07:00:00 PM by 1023595200 »
Offline heminut
« Reply #16 on: May 04, 2002 - 07:43:20 PM »
Rev-it-up that has GOT to be one of the best looking engines I have ever seen! Elegant, yet understated! :D
1970 5.7 Hemi Cuda
Offline Rev-It-Up
  • Global Moderator
« Reply #17 on: May 04, 2002 - 08:27:37 PM »
Thanks 392heminut.  There's a lot of blood, sweat, tears, elbow grease and spit polish on it.  Can't wait to hear her start up!
Offline wmiller
« Reply #18 on: May 04, 2002 - 09:39:07 PM »
Just a tid-bit of info here. A comment was made earlier in this string about sand blasting warping the hood. That is correct--if you use sand. The warping comes from the heat generated by the sand contacting the sheet metal surface at such a high rate of speed. Solution--use a much lower air pressure and keep the distance at a maximum to effectively remove the paint. The best media to use for removing paint is plastic beads. NO HEAT. NO PITTING (like sand) and no silica. I know of local vendors in my area who will come to your site--erect a tent (with a floor inside) roll your car inside and blast it to bare metal in no time. Absolutely beautiful job, very little clean up and, above all, extremely reasonable.
