Author Topic: seatbelt relay  (Read 1161 times)
Offline justin16440
seatbelt relay
« on: May 23, 2006 - 04:15:17 PM »
I was going to order a new engine harness but before I can I have to find out if my car had the seat belt relay.How can I tell if my 74cuda was a later or earlier model?I donot have the broadcastsheet or the original seats or any documentation.
Re: seatbelt relay
« Reply #1 on: May 23, 2006 - 04:40:27 PM »
I thought all 74's had the relay???  :clueless:
Offline rusty dodge
  • 74 challenger 440-727-3:55
Re: seatbelt relay
« Reply #2 on: May 23, 2006 - 04:59:50 PM »
Near the starter relay on the inner fender,there is another over ride relay bolted there. It has a mechanics over ride rubber push button on the top of it. It has an electrical plug going into it with like 4 wires of which there is a yellow , and also a yellow with black tracer. It is about the same size as the regular starter relay.
Offline justin16440
Re: seatbelt relay
« Reply #3 on: May 23, 2006 - 05:10:00 PM »
Ihave a yellow and a yellow and black wires that go to the starter relay I do not have 2 relays next to each other. just one
Offline rusty dodge
Re: seatbelt relay
« Reply #4 on: May 29, 2006 - 08:15:22 AM »
here is a picture of it. sounds like yours was removed.
the top electrical gadget with the red connector is the seat belt relay.
Offline justin16440
Re: seatbelt relay
« Reply #5 on: May 29, 2006 - 01:06:47 PM »
thanks for the picI have that red plug but not the relay. Looks like the 2 yellows are   spliced  together at the red plug.
Offline rusty dodge
Re: seatbelt relay
« Reply #6 on: May 30, 2006 - 07:15:58 AM »
I guess when you order your harness, you will need to decide if you want to keep it original looking and also get a seat belt relay, even though it dosent do anything.
I pitched all that stuff on mine. But I wasnt after a "correct" look. All that you need is the yellow wire, and it goes into the starter relay. You dont need the yellow black tracer wire.
What I found funny was that the blue wire in the red connector dosent even plug into anything.
Offline justin16440
Re: seatbelt relay
« Reply #7 on: May 30, 2006 - 02:46:14 PM »
My car is no wear near original so I won`t be putting the seatbelt relay back in. I just what it to start.When the new harness gets here Do I just plug the yellow in the starter relay and ignore the rest?
Offline rusty dodge
Re: seatbelt relay
« Reply #8 on: May 31, 2006 - 07:56:52 AM »
Did you get a harness with or without the relay connector?
You can probably leave it as it is and then you might need to do something with the wires under the seat if that isn't done already. Check that there is 12v on the starter relay, yellow wire, when you turn the key to start.
If not then the yellow from the red plug in the seat belt relay is the yellow to use in the starter relay. I believe this will be the case. Please check that this yellow comes directly from the firewall connector, and has the 12v like above. You will probably need to move this wire to the starter relay, or jumper it to there.
I just modified mine a few days ago. I made my own harness to relocate the starter relay, delete the seatbelt relay and move the battery to the trunk. But I didnt check to closely before I took it apart, to see what you would do like in your case where you wanted to keep the original harness.
kudakidd
Re: seatbelt relay
« Reply #9 on: June 01, 2006 - 01:02:25 PM »
The seat belt interlock system was unique to 1974 models. It was to prevent you from starting car until you buckled up!! There is a relay under the hood w/ a "stem" sticking out of the top of it. Check you owners manual on how to use it.
Find the starter relay. Find yellow wire attached to it. This wire is the feed during cranking to trip relay. You will likely find no voltage while in crank position. Make a permanent repair by running a new wire safely from the yellow ignition switch wire to the relay. That eliminates the interlock
