Author Topic: Which Holley ??  (Read 2058 times)
Offline Tropicalcats
  • Don't Ever, Ever Give Up
Which Holley ??
« on: May 24, 2006 - 02:31:34 PM »
I just talked with a previous owner of my car . He owned it from 74-89 and he tells me that the original carb was replace with a Carter. Which is on the car now. He said the original was a Holley.
What kind of holley would have been on a 70 Challenger 383 R/T  L.A. car?
SOLD
Offline ntstlgl1970
  • T a c o c a t
Re: Which Holley ??
« Reply #1 on: May 24, 2006 - 02:52:46 PM »
a holley 4160, the exact model number would depend on whether or not the car was a california car or not (the emissions package would have been different). The ca. cars had a bowl vent valve that was tied into the valve cover and fuel vapor seperator in the trunk, an electric solenoid vacuum advance on the distributor and an electrical connector on the carb.
Offline Challenger6pak
Re: Which Holley ??
« Reply #2 on: May 24, 2006 - 02:58:23 PM »
If you have a Carter carb the #'s are as follows:  #4732 & #4734 383 A/T W/ AC.  #4737 383 S/T.  #4736 383 A/T wo/ac.   The carbs are the AVS version. Maybe your Carter is the same as one of these and you have a carb someone else would need.
Re: Which Holley ??
« Reply #3 on: May 24, 2006 - 03:14:04 PM »
It is a Ca
SOLD
Re: Which Holley ??
« Reply #4 on: May 24, 2006 - 03:15:11 PM »
Thats good thinking I will check on the numbers>
SOLD
Offline ntstlgl1970
  • T a c o c a t
Re: Which Holley ??
« Reply #5 on: May 24, 2006 - 03:49:09 PM »
R4360-A or R4366-A are the only two numbers I could find in an old motors book. Might have something different in the factory service manual. The carb is pretty specific though, since the bowl vent valve feeds a tube instead of dumping to the atmosphere and has a green wire with a grey (I think) connector to connect to the distributor vaccum advance can/solenoid. Once you see one, you can pick it out of a pile of holleys in an instant, the good thing is usually if you see one at a swap meet, no one wants it so it goes for cheap!
Offline Robb
Re: Which Holley ??
« Reply #6 on: May 25, 2006 - 08:44:44 PM »
It is a Ca
yeah but is it an "Emissions" CA car ?
Fender tag:
N95     NOx Exhaust Emission Control, Calf. Emission Control PAckage
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
Re: Which Holley ??
« Reply #7 on: May 25, 2006 - 09:31:50 PM »
Fender tag:
Yes N95 car
R4360-A or R4366-A . Anybody have one
SOLD
Offline Robb
Re: Which Holley ??
« Reply #8 on: May 25, 2006 - 10:21:13 PM »
Yes N95 car
I did a quick net search of the those numbers.... and theres nothing on the web about mopar or carter or holley and those numbers.
might try this guy though
http://www.thecarburetorshop.com/
Re: Which Holley ??
« Reply #9 on: May 26, 2006 - 04:58:48 AM »
Thanks
SOLD
Offline ntstlgl1970
  • T a c o c a t
Re: Which Holley ??
« Reply #10 on: May 26, 2006 - 11:10:11 AM »
I got those numbers from a 73 motors manual, I'll see what I can dig up from the factory manual a little later today.
