Author Topic: Fixing over assisted power steering  (Read 4958 times)
Offline willj
Re: Fixing over assisted power steering
« Reply #15 on: May 27, 2006 - 08:17:35 PM »
adding caster to the front suspension set up helps a lot with stability of the car & adds load to the power steering as well
Chryco can u explain how u do this? and could u also explain how this doesn't wear tires? any and all info is muchly appreciated, thanks, Will.
73 Challenger 318 4 spd
« Reply #16 on: May 27, 2006 - 10:00:35 PM »
by tilting the upper control arm & ball joint rearward , this increases caster the more you tilt it the more the car wants to go straight & the harder the car becomes to turn & the easier it will correct to straight after a corner , this has zero effect on tire wear assuming the camber & toe are corrected after adjusting the caster  , at high speed the increased castor helps the car not feel like it is wandering as well
Offline willj
« Reply #17 on: May 27, 2006 - 10:27:26 PM »
thank you Chryco  :cheers:
Offline oldkimmer
« Reply #18 on: October 31, 2006 - 09:48:13 PM »
Give Bill a call at Reilly Motor Sports............www.rms.com            He has a kit for changing the pressure to your liking...........He can be found on ...bigblockdart.com.............a very good site.........Kim
The beast has been unleashed........Thems the hazzards..........Unleash the beast......
« Reply #19 on: November 01, 2006 - 07:17:51 AM »
rms.com not correct shoud be http://www.reillymotorsports.com ? has lots of suspension parts.
 oldkimmer are you refering to Power Steering Pump Pressure?
Offline oldkimmer
« Reply #20 on: November 02, 2006 - 07:09:11 AM »
yes
Offline PlumCrazyChris
    • Mopar Muscle Cars of Austin
« Reply #21 on: November 16, 2006 - 09:27:43 AM »
Go find yourself a power steering gearbox off an Diplomat/gran fury cop car.  Swap it in with a new pitman arm and you'll have a great cheap firm feel steering gear.  I did this in both of my 70  challengers and it is really one of the best upgrades I've done on them.  I got the box for about $35 at a local yard.  There are a lot of good parts on those cop cars, especially if your running a smallblock.  Check out the radiators, heads, disc brakes and kickdown linkage too, very nice.
PlumCrazyChris
Round Rock Tx
70 Challenger 5.7, A518, A/C
70 Challenger 340 convertible (Gone to Sweden)
68 Barracuda (sold it too)
www.mopar.org
Offline dodge freak 2
« Reply #22 on: November 19, 2006 - 07:24:44 PM »
That and also all new ball joints. I replace just my uppers this summer and notice the steering wheel was a bit stifer. Not sure how long it last but if I would have change all 4 it would have been even more noticable. Don't know if tie rods get easyier to move as they get old too.
« Reply #23 on: November 20, 2006 - 06:00:58 AM »
From what I can gather the difference in the Firm Feel box as well as the Cop box & stock is the pressure allowed, which Firm Feel states is accomplished by using different springs in the box. Maybe oldkimmers guys kit is for these?
Also the faster ratios, at least on the AAR & T/A, is accomplished by a longer pitman arm, which also causes the wheel to turn more & can cause wheel to fender clearance issues.
Offline 71_340Challenger
« Reply #24 on: December 20, 2006 - 10:57:27 AM »
As a note, I talked to a guy this last summer that built a cobra kit car and had a similar problem. His is based off the 90's Mustang and with the cobra fiberglass body and shorter wheel base, there was just too much power steering. Anyway, he mentioned that he bought a kit somewhere that bolt in a meetering block with a check valve that reduced the line pressure and therefore the amount of steering assist. He said it worked great and only took a couple of hours to install. Unfortunately, I don't remember where he said he got it. I will see if I can get a hold of him again and see where he got it and pass it along.
1971 Dodge Challenger
2009 Dodge Challenger R/T, 6 speed manual
2009 Dodge Charger R/T w/ Road & Track Package
1995 Ford F-150
Offline r15303
« Reply #25 on: December 20, 2006 - 04:16:43 PM »
Try a company called Firm Feel.  They have a web site and can re do your gear box for a firmer feel and also sell tubular upper control arms to easilly adjust your caster.  I have not bought from them yet but probably will.  The guy I talked to is Dick and seemed to know his stuff.  He is recommending 3 - 3.5 degree caster to make the car want to run straight as it comes out of turns.  Their phone # is  360-546-3633.
