Author Topic: Corvette guys spy an AAR? You'd think it was an alien spaceship!  (Read 9102 times)
Offline hotrod98
    • Maniac Musclecars
Re: Corvette guys spy an AAR? You'd think it was an alien spaceship!
« Reply #45 on: May 31, 2006 - 02:59:14 PM »
Normally, no, but if you'll notice, the rear ends aren't always centered in the car for some reason. All four of my e-bodies vary a little. 10" rims may require the offset spring hangers.
« Last Edit: May 31, 2006 - 03:01:40 PM by hotrod98 »
1971 Cuda, Tor-red, Bench seat
1971 Cuda Drag Car
1973 Cuda Clone, EFI/OD Limelight
1970 Superbird (Yes, it's real) Black Ice
1971 Barracuda Sassy Grass Green (sold)
1970 Challenger RT SE 383 Plum Crazy
1969 Road Runner Hardtop
1968 Road Runner Coupe (sold)
www.maniacmusclecars.com
Offline Blackcuda
« Reply #46 on: May 31, 2006 - 03:11:57 PM »
Thanks for the info, I have been sticking with 8" wide wheels with my cars, but would like to go with 9".
KTO
« Reply #47 on: May 31, 2006 - 06:59:46 PM »
« Last Edit: May 31, 2006 - 07:11:00 PM by KTO »
KTO
« Reply #48 on: May 31, 2006 - 07:09:47 PM »
I think you would have tons of room with a 9" wheel and a 5" backspace. The 73 has 9" rear wheels 4.5" backspace using  285/40 17" wheels (26" tall and 11" wide) and if I remeber right, there is at least 2" of clearance between the tires and springs.  The same holds true on my 64 and 66 b bodies. The inner clearance isnt a problem, just the outer wheel well. I dont think you would need a sping relocation kit unless you were tubbed and had a narrowed axle.
Here is a picture...
It's pretty easy to measure your backspace and wheel width...
just plum a line down from the spring and the face of the drum where the wheel mounts. That should be your max backspace measurement. Then plum a line from the wheel well and measure from that point to the drum line. That measurement plus your 1st backspace measurement can be used to figure your max wheel width.
Of course you'll have to subtract about an inch off both measurements for inner and outer for tire clearance.
I do agree with hotrod98 though. My coronets driver wheel is over 1/2" closer to the spring than the passenger. This may be why we see a lot of this type of question and no one really has a solid answer. Different shackles, different tire heights, different inner wheel wells, different spring wear, misaligned quarters and patch panels. Too many variables.
I may be talking out my a ss though. I do have a few beers in me, but I'd say a 9" wheel with 5" backspace and a 11" tire will fit just fine, :)
I'd say do your measurements and go a little conservative on the rear tire width. If your smaller rear tires clear by a mile you can always burn them off and head down to wal mart for a new set of wider tires...........and then burn them off until you get it right :)
« Last Edit: May 31, 2006 - 07:22:33 PM by KTO »
Offline hotrod98
    • Maniac Musclecars
« Reply #49 on: May 31, 2006 - 08:02:24 PM »
 :bigsmile:
1971 Cuda Drag Car
Offline Blackcuda
« Reply #50 on: May 31, 2006 - 08:16:30 PM »
I just installed these Boyd Junk Yard Dogs 17X8's front and back. They look good, but I would have liked 9'' wide rears.
« Last Edit: May 31, 2006 - 08:18:48 PM by Rev-It-Up »
KTO
« Reply #51 on: May 31, 2006 - 09:09:28 PM »
Those are great looking wheels. They look like Smoothies or torq thrusts but with more open space between the spokes. They would look super sharp with front and rear disc brakes :)
Offline chevyconvert
  • HvacMan
  • Member since November 04, 2005
« Reply #52 on: June 01, 2006 - 12:18:53 AM »
Those J.Yards widths jump from 8" to 10" on the 17" Diameter according to one WWW. seller I just looked at.
Eric
'70 Hemi Orange RT/SE 440 Six Pack Pistol-Grip 4 speed
Bay Area California
Offline hotrod98
    • Maniac Musclecars
« Reply #53 on: June 01, 2006 - 07:07:39 AM »
I just bought Boyds Smoothies for my 70 challenger convert. I went with 17 x 7's in the front and 17 x 8's in the back with Goodyear F1 GS D3's. The tires are 26" tall which gives them a nice look and a nice ride. I decided to go conservative since I definitely didn't want to have one of those expensive tires getting chewed up. The chal is not quite finished so I put them on my 71 Cuda just for kicks. I may have to buy another set now. At least the smoothies are somewhat affordable. I paid $1800 for the rims, tires, lugnuts, mounting, balancing and shipping. The Billet Magnum 500's that I was thinking about buying would have cost over $1600 just for the wheels.
1971 Cuda Drag Car
Offline Blackcuda
« Reply #54 on: June 01, 2006 - 07:28:30 AM »
You can't see from the pic, but my car has front disc brakes and I painted the calipers red.
Here's a pic of the wheel close up.
« Last Edit: June 01, 2006 - 07:35:21 AM by Rev-It-Up »
  • HvacMan
« Reply #55 on: June 01, 2006 - 11:35:27 PM »
You guys are REALLY tempting me to spend some bucks !!
Especially since I'd have to add rear discs too.
Those wheels make those cars look Bad A$$ !!! :thumbsup:
But we digress, anything on the AAR ?
Eric
Bay Area California
