Author Topic: HELP.... Carb issue  (Read 2496 times)
Offline ROMI
  • 71 Challenger R/T 340 4 speed, Lapeer Michigan
HELP.... Carb issue
« on: May 26, 2006 - 09:26:04 PM »
I went out crusin tonight and as I pulled up to make a left at the first major road, I stalled it out.  I did this a couple of more times before I realized it wasn't my lack of driving skill that was causing it.  Something has changed since last fall.  The only thing I changed was to put the correct unsilenced black air cleaner on.  The carb is an Edelbrock 650.  Here's what's happening.  From an idle, at a stop, when I accelerate quick, I THINK it's dumping a bit too much fuel. if I kind of tap it before I go then most of the time I'm alright.  Now this works all the time, if I keep the rpms up to 1500 then I can do what ever I like and it runs great. Everything over 1500 is just fine. What bugs me the most is that I didn't change anything except the air cleaner from a 72 version to the 71 unsilenced type. Any one got any ideas what my problem is (Chryco)?
Re: HELP.... Carb issue
« Reply #1 on: May 26, 2006 - 09:30:30 PM »
gum in the carb from siting? maybe floats sticking
Offline ROMI
« Reply #2 on: May 26, 2006 - 09:35:32 PM »
Yeah that's possible. How do you check and how do you get rid of it?
« Reply #3 on: May 26, 2006 - 09:41:17 PM »
Man your talkin to the wrong guy but you could always add some cleaner to the tank & drive the PISS out of it  :icon16:
Offline ROMI
« Reply #4 on: May 26, 2006 - 09:44:52 PM »
I can handle that!
« Reply #5 on: May 26, 2006 - 09:52:56 PM »
Seriously before I got tooo deep into trying to fix anything I'd add some Lucas fuel treatment & put a few highway miles on it. Don't think it's a fuel pump that would show up more at high RPM, one possibility I thought of was could the new air cleaner be interfering with linkage, those do drop down lower than some.   :smokin:
« Reply #6 on: May 27, 2006 - 05:24:47 AM »
the accelerator pumps are notorious for drying up when they sit & then not squirting fuel  the pump is available separatly without buying a complete kit , replace it & the problem will go away til next spring
« Reply #7 on: May 27, 2006 - 06:28:39 AM »
 :iagree:  a simple test for that is when the car is cold, been sitting for a day or so, you have to pump the accelerator a bunch to get it to fire
Offline ROMI
« Reply #8 on: May 27, 2006 - 06:54:32 AM »
Thanks guys.  That accelerator pump idea sounds like the issues to me.
I told my buddy every time we stopped that I knew WHO would know what was wrong (Chryco).
Thanks again Bullitt and Chryco.
Now I gotta find out where to get one. It sure would be nice to find one today at a store somewhere.
« Reply #9 on: May 27, 2006 - 07:12:09 AM »
you might try Advance. I ordered brake shoes on Sat. P/u on Sun.
http://www.partsamerica.com/ProductList.aspx?categorycode=3339Q
Offline ROMI
« Reply #10 on: May 27, 2006 - 07:39:03 AM »
Thanks Bullitt, I went to Edelbrock.com and found 3 dealers within 10 miles of me. Two of them were Autozone. Here's hoping they stock the pump.
Offline ROMI
« Reply #11 on: May 27, 2006 - 03:27:39 PM »
I got to thinking about the fact that my carb is a manual choke and realized that I don't have a cable or anything hooked up to it. I went out, took off the air cleaner and pumped the throttle by hand 3 times and each time, plenty of fuel came out.  I then started it up and started putting the choke in different positions and found that if I closed it just a little bit that it seemed to give me the same results as if I was sitting at a light feathering it waiting to take off.
I hate to appear stupid but could that be my problem instead of the accelerator pump or am I just compensating for something else being wrong? I'd say 1/8 inch travel made a big difference.
I know this doesn't seem like a big deal but when your sitting at a light trying to turn left, stalling and difficulty restarting is not my idea of cruising.
« Reply #12 on: May 27, 2006 - 05:44:31 PM »
When you close the choke you are limiting the amount of air therefore enriching the mixture. adjusting your mixture screws would correct. BUT if you have a gum buildup that will do away with some driving you will need to adjust back after the gum dissipates. :2cents:
Offline Grancoupe
« Reply #13 on: May 27, 2006 - 07:13:12 PM »
Choke thing happened to me on a Holley 750 I had. No cable to keep the thing open and it started closing aand stalling on hard throttles.I tie strapped it open and it solved the problem. Worth a try on your end...
« Reply #14 on: May 27, 2006 - 09:53:14 PM »
I usually cut a piece of coathanger wire & insert it into the choke mechaism so it cannot come on
 I do this as I install the carb so I have never had that problem
