Author Topic: 15 x 7 wheels on late e-body  (Read 2894 times)
Offline RusTy/SE
  • Just havin' fun
« on: April 18, 2003 - 12:00:41 PM »
Has anyone had any experience with 15x7 wheels on a 73 e-body ? They were not available from the facory after 71 on e-bods. Can i expect rubbing on the fronts when making turns ?
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Re:15 x 7 wheels on late e-body
« Reply #1 on: April 18, 2003 - 01:16:56 PM »
sAME SUSPENSION AS THE EARLIER e BODIES , THEY FIT FINE
 I hate caps lock
Offline RusTy/SE
  • Just havin' fun
« Reply #2 on: April 18, 2003 - 02:47:21 PM »
Thanks, CP. 15 x 7 chrome magnums for me.    :)
Russ
2001 Durango     1B4HS
Offline AustinChallenger
« Reply #3 on: April 24, 2003 - 09:07:18 AM »
I have 15 x 7 with p275 60/15 tires on the back of my 74 Challenger with no problems.
1974 #'s matching Duster 360
Offline RusTy/SE
  • Just havin' fun
« Reply #4 on: April 24, 2003 - 06:48:35 PM »
Thanks AustinChallenger. Btw i went to your webpage and one of your engine photos answered my alternator belt question. Whoever put the engine in my 73 has the belt going from the crank pulley to the alt instead of including the fan pulley in the route. I'll be junkyarding it monday for the correct alt. brackets and buying a new belt. I was stumped as to why it would squeal whenever i gave more than a certain amount of gas to the engine. I'll bet the wrong fan is on too as it's too big for the shroud but doesn't extend far enough to chew it up (the shroud). In some of your photos your Challenger looks JY3 (honey gold i think) and others it looks Top Banana but they all look good. Is Blaze Yellow somewhere in between ? Anyhoo countless thanx for the solution to my belt problem.
Russ    :D :D :D
« Last Edit: April 25, 2003 - 10:58:12 AM by onefornow »
Russ
2001 Durango     1B4HS
