Author Topic: B-body 8 3/4 in E-body?  (Read 1919 times)
Offline TripleBlack71Cuda
  • Member since 3/21/2006
    • 1970 & 1971 Cuda Video
« on: May 28, 2006 - 03:03:22 PM »
Are there any issues with fitting an 8 3/4 rear end out of a B-body under an E-body, or are they interchangeable?   :dunno:
Offline heminut
Re: B-body 8 3/4 in E-body?
« Reply #1 on: May 28, 2006 - 04:12:48 PM »
You will either have to move the springs in or the spring perches out. I have put B body housings in both the Cudas I've owned, as they are easy to find, and it gives you about 3/4" extra tire clearance on each side. I have gone the route of moving the spring perches in both times that I've done this swap. I believe there is about 1/2" difference on each side. It's my understanding that the Mopar Performance offset shackles and front spring hangers will set the springs in the right amount so that the B body housing is a bolt-in, but I have always gone the cheaper route of relocating the perches.
1970 5.7 Hemi Cuda
Alaskan_TA
« Reply #2 on: May 28, 2006 - 04:59:53 PM »
The MP brackets move the springs in 3/4" on each side, they can be used, but 1" is needed. Dr. Diff has a 1" offset kit that is an easy bolt in and fairly priced too. You can find them at http://members.aol.com/doctordiff/other.html
Barry
« Reply #3 on: May 28, 2006 - 10:02:37 PM »
Thanks for the info guys!
« Reply #4 on: May 29, 2006 - 12:08:45 AM »
B bdoy diffs were differnt widths depending on the year , up to 70 they were  narrower than th eE body , in 71 they were a lot wider than th eearlier diff
Offline PlumCrazyChris
    • Mopar Muscle Cars of Austin
« Reply #5 on: June 21, 2006 - 04:11:28 PM »
This is info that I just found out myself, but will soon be spread all over the E-body World.  A 65-69 C-body and very likely a 65-70 A100 van 8 3/4 rear will bolt into a E-body perfectly.  The only difference is it is 1/8" wider at the hubs.... and it may have bigger brakes.
There it is, its out there.  Spread the word.
PlumCrazyChris
Austin, Tx
70 Challenger 340 Convertible
70 Challenger 340
PlumCrazyChris
Round Rock Tx
70 Challenger 5.7, A518, A/C
70 Challenger 340 convertible (Gone to Sweden)
68 Barracuda (sold it too)
www.mopar.org
