Author Topic: sanden a/c compressor on smallblock  (Read 11826 times)
Offline Got JOB
  • Member since 2-14-06
« on: May 28, 2006 - 07:36:23 PM »
anyone have pictures of changing out factory a/c compressor to sanden compressor on smallblocks
70 T/A Plum crazy
71 vert. viper red
74 Rallye triple black ( sold )
76 Aspen Wagon
West Georgia
Offline miketyler
    • www.miketyler.net
Re: sanden a/c compressor on smallblock
« Reply #1 on: May 28, 2006 - 08:17:45 PM »
I'm doing that very thing on my 340 right now. Am having to go with a custom pulleys and brackets. If you are interested I have a Sanden mount kit for SB mopar if you are interested. Most parts have been chromed. By the time I started to put it on I realized it wouldnt work with my aftermarket MP manifold.
The kit was purchased from old air products and details are here:
http://www.oldairproducts.com/shop/product_info.php?cPath=30000000_60000000_69000013&products_id=3513&osCsid=84c384bd950472cac6c6685d274bb81d
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline Got JOB
« Reply #2 on: May 28, 2006 - 08:41:07 PM »
I noticed the bracket had an idler pulley. I have seen an install that used no idler,belt tension was as stock with alt. Don't know who makes kit or whether it was custom. Just planning conversion now and getting ideas. Will keep your bracket in mind. Thanks Ricky
70 T/A Plum crazy
71 vert. viper red
76 Aspen Wagon
West Georgia
Offline miketyler
    • www.miketyler.net
« Reply #3 on: May 28, 2006 - 08:53:58 PM »
I dont know of any kits for small blocks unledd you have original brackets and setup for the RV4. they make a saddle plate that mounts the Sanden in the same position as the RV4 and uses the alt as the tensioner. To my knowledge, the alt tensioner/dual belt setup would have to be custom. This guy has some pretty well designed kits. Ck him out
 http://bouchillonperformance.com/BPEACmountingbrackets.asp
72' Cuda restomod
70 Mustang Mach 1
Offline Got JOB
« Reply #4 on: May 28, 2006 - 09:23:34 PM »
That is the install I saw at a show. It was on an A-body. Wonder if you could just use the small compressor and make up hoses and use the same condenser, dryer, expansion valve. Thanks for the info and link. Ricky
70 T/A Plum crazy
71 vert. viper red
76 Aspen Wagon
West Georgia
Offline ShelbyDogg
« Reply #5 on: May 29, 2006 - 03:12:10 AM »
I went to the local Pick and Pull and saw 4 small blocks with the new style compressor.  The brackets were a little different than the V type, but were complete. Seems like the junk yards around you should have the same small blocks around. Most of these still had pressure in them.
Offline Mopar73340
« Reply #6 on: May 29, 2006 - 07:06:19 PM »
To answer your question all of the original parts can be used, I have converted both of my e-bodys to sanden compressors. You can find the bracket and compressor at Bouchillon performance as stated above. You will only use 1 belt though. Seems to work fine as the sanden compressor takes a fraction of the HP to run as the RV2. I attached a pic minus the hoses to the compressor which just need the sanden ends attached with a bubble crimping tool. I like this setup because you don't use an idler pulley and you also use all of your existing pulleys. If you want a pic of the complete setup I can get it tomorrow.
« Last Edit: June 19, 2006 - 06:52:54 PM by Rev-It-Up »
Offline Got JOB
« Reply #7 on: May 29, 2006 - 07:43:57 PM »
That setup looks great. post another picture with hoses attached if you don't mind. Thanks.
70 T/A Plum crazy
71 vert. viper red
76 Aspen Wagon
West Georgia
Offline Mopar73340
« Reply #8 on: May 30, 2006 - 01:55:36 PM »
Try this one..........
« Last Edit: June 19, 2006 - 06:53:18 PM by Rev-It-Up »
Offline Got JOB
« Reply #9 on: May 30, 2006 - 05:02:14 PM »
Thanks, that looks neat and clean. Does the compressor have the brace bar that attaches to the drivers side head?
70 T/A Plum crazy
71 vert. viper red
76 Aspen Wagon
West Georgia
Offline Mopar73340
« Reply #10 on: May 31, 2006 - 02:03:52 PM »
Yes the brace is there, although I think it would work fine without it.
Offline Robb
« Reply #11 on: May 31, 2006 - 03:36:36 PM »
I am interested in what you did here as my car is also A/C though I released the cooling stuff when I did a motor swap and have not recharged it yet.....
So....
Everything/Everything except the hose ends and the compressor/brackets are factory equipment ?
did you put in a cycling switch ?
http://bouchillonperformance.com/BPEac_cycling_switch.asp
According to BP website the old RV2s didnt use a cycling switch but the Sandens do ?  You need to put a probe on the part of the hose that is right at the firewall goin on into the heater box.  (pics are on the BP site) regarding cycling switch.
Youre install really looks a lot better than the demo cuda install that is on the BP site.   :cheers:
« Last Edit: May 31, 2006 - 03:40:54 PM by Robb »
70 Challenger SE  (440 SIX PACK / Keisler 5 speed, R/T SE replication)       68 Sport Satellite Convertible 383 Super Commando / 727  Survivor
2002 Trans AM WS6 convertible:  DD
1999 4Runner 4x4:  lifted-locked-armored  expedition vehicle
1990 Jeep XJ 4x4:  Front Dana 60, GM-14bolt rear, 3 link, 4link, 5.38 detroits, beadlocked 40's, stretched to 110" wb  Rock Crawler
Offline Mopar73340
« Reply #12 on: May 31, 2006 - 04:21:17 PM »
Robb, thanks. Everything on my setup is orignally how the factory installed it. The condenser, evaporator, dryer, and all lines are factory parts, the only deviation is the compressor, compressor mounting bracket, and the hose ends at the compressor. I didn't want to modify my car so I decided to go with the factory parts. Bouchillon's car is ok but it dosen't look right to me. (They also argued with me about doing it my way) I also installed a cycling switch at the suction line as it exits the evaporator. If you need more pics or info let me know. Jim
« Last Edit: May 31, 2006 - 04:24:59 PM by Mopar73340 »
Offline Got JOB
« Reply #13 on: May 31, 2006 - 04:29:19 PM »
doesn't a stock setup have a cycling switch? I have a probe that is attached to the expansion valve. the probe end is under a piece of foam on the large line at the firewall. the stock setup also has a pressure switch on the dryer.
70 T/A Plum crazy
71 vert. viper red
76 Aspen Wagon
West Georgia
Offline Mopar73340
« Reply #14 on: May 31, 2006 - 04:33:56 PM »
Those probes are for the expansion valve, there was no cycling switch from the factory in the early 70's, and yes there is a low press cutoff switch on the dryer
