Author Topic: sanden a/c compressor on smallblock  (Read 11828 times)
Offline miketyler
    • www.miketyler.net
Re: sanden a/c compressor on smallblock
« Reply #30 on: June 08, 2006 - 05:59:11 AM »
Deja-Vu! I just cut mine last night also. Am sending them off today for crimping. I would have considered the Bouchillion solution if I could have kept my March Performance pulleys.
I got my parts from Old Air products and they sent me an adjustable thermostat. I called them on it and they said it should work to my benefit since I was only going to attach the capillary line to the suction tube. They said the optimal position was inserted within the evap coils. My box is already been overhauled and I'm not pulling it back out!
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline Mopar73340
« Reply #31 on: June 08, 2006 - 01:43:31 PM »
Looks great GJ.   :thumbsup:
MT, I was in the same situation with the evap, that is why I installed the temp probe on the suction line.
Offline miketyler
    • www.miketyler.net
« Reply #32 on: June 10, 2006 - 07:07:32 AM »
Mopar73340 - are you running 134A? How does it perform for you? I am wrapping up the hard plumbing on the condensor and hope to get my valance, front grille and bumper back on this weekend.
« Last Edit: June 10, 2006 - 03:05:02 PM by miketyler »
72' Cuda restomod
70 Mustang Mach 1
Offline Mopar73340
« Reply #33 on: June 10, 2006 - 08:50:25 AM »
MT, Yes I'm using 134A.  I have not run the sanden setup yet in hot temps with the 134A. I used the 134A with the RV2 the last few years in my other Challenger and it seemed to work about the same as the R12.
Offline miketyler
    • www.miketyler.net
« Reply #34 on: June 11, 2006 - 07:09:58 AM »
The guys at Old Air told me that the clutch wiring should run like this: AC pwr switch -> tstat-> pressure switch-> compressor. If either the tstat will or pressure switch will kill power to the clutch, what difference would it make? Intuitively I would have thought the pressure switch should have been further up stream and closer to the power source. They explained it but I didn't get it. Can anyone "dumb it down" for me?
72' Cuda restomod
70 Mustang Mach 1
Offline Mopar73340
« Reply #35 on: June 11, 2006 - 08:25:51 AM »
I don't see what difference it would make either. It's a series circuit so it should't matter which way it's wired. One switch or the other will break the circuit. On the other hand, if you wire it from the bulkhead, the temp switch is most likely closer and therfore you would hit that one first before the low press switch??  Maybe that's their logic??
Any other suggestions?
Offline miketyler
    • www.miketyler.net
« Reply #36 on: June 11, 2006 - 07:36:35 PM »
I may call them about that tomorrow to see if they can help me understand. They also said the optimum position for the expansion valve is 45o down. So that would be 4:00 or 8:00 position. Liquid can form in one that is positioned straight down. Again, not sure I understand all the AC voodoo here but I am going with what they say
72' Cuda restomod
70 Mustang Mach 1
Offline Mopar73340
« Reply #37 on: June 12, 2006 - 01:56:14 PM »
All of the factory one's that I've seen were installed at 9 o'clock facing the firewall from the front. That is how I have mine.
Offline Mopar73340
« Reply #38 on: June 17, 2006 - 09:52:12 AM »
Update, I drove my White car today in 90* heat, using 134A and the cycling switch. The compressor cycled on and off just like it's supposed to. The air felt as cold as my Neon so I guess it's working ok.
MT- I guess there is a reason for the wiring to the t-stat first as my other car (Red one) is not wired that way. Both A/C systems are set up identical (Factory parts & Sanden Comp), but it won't cycle so I'm going to change it around and try again.
« Last Edit: June 17, 2006 - 09:54:31 AM by Mopar73340 »
Offline miketyler
    • www.miketyler.net
« Reply #39 on: June 17, 2006 - 03:09:37 PM »
I cant understand it making any difference; I would sooner believe it is an issue with the t-stat switch. The guys at Old Air told me to attach the sense line as close to the evaporator as possible and since the evap was enclosed, make sure it is contacting the suction line good. If you have any air gap that might be contributing. Is the suction line getting nice and cold and sweating up ok?
72' Cuda restomod
70 Mustang Mach 1
Offline Got JOB
  • Member since 2-14-06
« Reply #40 on: June 19, 2006 - 06:12:00 PM »
Finally finished my lines today. Did a little different on the high side by adding an extra port. I was afraid the gauges would not hook with my low and high ports so close together. Think on my vert. I might put the ports in-line where I put the lines together.
70 T/A Plum crazy
71 vert. viper red
74 Rallye triple black ( sold )
76 Aspen Wagon
West Georgia
Offline miketyler
    • www.miketyler.net
« Reply #41 on: June 19, 2006 - 06:51:44 PM »
Lookin pretty slick there GJ - got her charged up and pumpin' yet?
« Last Edit: June 19, 2006 - 07:51:28 PM by miketyler »
72' Cuda restomod
70 Mustang Mach 1
Offline Got JOB
« Reply #42 on: June 19, 2006 - 07:42:54 PM »
will try to charge up Wed. or Thur.
70 T/A Plum crazy
71 vert. viper red
76 Aspen Wagon
West Georgia
Offline Ravage
  • 1974 318 'Cuda
« Reply #43 on: June 19, 2006 - 07:45:10 PM »
Cheap AND easy  :thumbsup:
"I flipped off a box of kittens once..." (Tycho on being evil)
Offline miketyler
    • www.miketyler.net
« Reply #44 on: June 19, 2006 - 07:54:10 PM »
Now THAT is waaaayyyy too funny!!! Ck it out, looks like they replaced the original tail light lense with a pair of trailer tail lights. NICE!!!!!  :thumbsup: :biggrin: :thumbsup:
72' Cuda restomod
70 Mustang Mach 1
