Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Suspension, Wheels/Tires, and Brakes
(Moderator:
Chryco Psycho
Removal manual steering box
« previous
next »
Print
Pages: [
1
Author
Topic: Removal manual steering box (Read 878 times)
70RAGTOPR/T
Jr. Member
on:
May 29, 2006 - 02:46:02 PM »
need instruction on removing a manual steering box. The steering column is still attached. If you have pic that would be great.
Thanks
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Removal manual steering box
Reply #1 on:
May 29, 2006 - 05:58:55 PM »
romove the roll pin from the coupler & pry it up with a tie rod pickle fork , you will need to drop the column to do this , split the center link from the pitman arm & undo the 3 bolts holding the box to the K frame
Logged
70RAGTOPR/T
Jr. Member
Reply #2 on:
May 30, 2006 - 07:59:47 AM »
Chryco......The pin was jammed in the coupler. Can it be drilled out? As for dropping the column, do mean unbolt it from the firewall?
Logged
ShelbyDogg
Sr. Resident
Reply #3 on:
May 30, 2006 - 08:53:26 AM »
That pin doesn't stand a chance to be jammed if you use the right size punch. Or just get a steel rod or bolt or anything smaller in diameter than that hole and drive it out with a big hammer. Unbolt the column from the firewall AND the 2 7/16 bolts at the dash support.
Logged
4Cruizn
Administrator
C-C.com Expert
HEMI FISH
Reply #4 on:
May 30, 2006 - 10:02:14 AM »
That little bugger just needs a little persuation and it'll come out. I just did mine on the hardtop alittle bit ago and definitely took some work! Keep at it!!
Logged
70RAGTOPR/T
Jr. Member
Reply #5 on:
May 30, 2006 - 10:19:14 AM »
All....Thanks for the advise. I'll work on it again. Note the pin's head was driven down in the coupler. I'll find a small hole punch a drive it out. If need be I'll use the bigger hammer theroy.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
