Author Topic: Disc Brake Coversion, B-Body  (Read 3371 times)
Offline R/T hedkace
« on: May 30, 2006 - 06:23:55 PM »
Hey guys, I know it's a shot in the dark asking on an E-body site, but I know this is a knowledgable crowd.  :worshippy
I'm doing a disc brake conversion swap on my fathers 69 Coronet R/T, and I have two questions I hope can be answered.  :1zhelp:
1) Is the original master clyinder alright to use? (Original big block car/ power brakes)
2) does anybody know exactly how these brackets fit onto the calipers? (pic #2)
Any help at all would be greatly appreciated.  :thumbsup:    Thanks all
Jeff
    Defending the Earth from "uptight" mods!!   an endless crusade..........
1970 Dodge Challenger R/T 440 4speed Dana
1970 Dodge Super Bee
1969 Barracuda
 Massachusetts
Offline ShelbyDogg
Re: Disc Brake Coversion, B-Body
« Reply #1 on: May 30, 2006 - 09:09:12 PM »
Darn, I was just at the junk yard last week to get 2 rotors, I just unbolted those pieces that you're asking about and threw them on the ground.  I have the pin type calipers and never had to note how that type was stacked.
If I remember correctly, everything is stacked; large plate, then medium plate, small plate, then the bolt. It just keeps pressure on the sliding caliper holding it down.  I don't think that you can put them on the wrong way as the bolt hole is offset.  If you get to a junk yard with old mopars, you'll see lots of that type of caliper. Just trial fit it and see how it fits.
« Reply #2 on: May 30, 2006 - 11:39:38 PM »
use the large plate & the small spring clip ONLY
 large plate on the bottom & the spring on top with thew narrower end of the clip bending down through the recess in the larger plate as an anti ratlle spring touching the pad
Offline Plum6Pak
  • Plum6Pak
« Reply #3 on: May 31, 2006 - 06:44:13 AM »
Nice looking job R/T, I've done the same exact swap. The later police style rotors and pin type are the most sought after but these are good too. This is a very popular swap from the 73-76 'A' bodies. The plates measure about 4" across, I only have the one size top and bottom.
« Last Edit: May 31, 2006 - 06:48:48 AM by Plum6Pak »
« Reply #4 on: May 31, 2006 - 10:34:41 AM »
I notice no one is addressing the Master Cylinder issue. I have no experience but suspect, based on other things I have read, that there will need to be a change of master cylinder or an adjustable brake bias installed.
WHO OUT THERE KNOWS?
Offline ShelbyDogg
« Reply #5 on: May 31, 2006 - 11:04:01 AM »
OOps,   Yeah the master cylinder will have to be changed to a disk brake master cylinder. The drum brake type does not have a large enough resevoir, piston,  and contains residual pressure valves.
Thanks Bullit99
Offline R/T hedkace
« Reply #6 on: June 01, 2006 - 07:22:21 PM »
Thanks so much everyone one of you  :worshippy :clapping: :cooldancing: You've all been a tremendous help  :cheers:
 Now that I know the center brackets in my pic are the wrong ones, I sent an email explaining the situation, and how I was sent the wrong brackets, and would appreciatie the correct ones be sent to me. I've not heard anything back yet  :pullinghair: Even the picture advertisement from where the kit came from shows the 4 correct brackets.
 The New England Summer Nationals are coming up in about three weeks in my home town :stomp: and I need to get this done immediately. WTF  :swear:
 Now the master cylinder also  :faint: If worse comes to worse the master cylinder out of my 440 R/T Challenger is at hand.. Anyone got any ideas where I can get those brackets, or the correct master cylinder setup  :dunno: :1zhelp:  :1zhelp:  Thanks again  :thumbsup:
Jeff
1969 Barracuda
 Massachusetts
Offline 422STROKER
  • Member Since 6/3/06
« Reply #7 on: June 04, 2006 - 11:48:19 AM »
Try autozone for a rebuilt m/c any disk m/c will work  theirs have bleeder kits and the rubber retainer with it for  around 20 bucks!
good luck I just did a swap on my chall messy work.
tom
Tom
Offline ChallengerHK
« Reply #8 on: June 05, 2006 - 06:24:02 AM »
If I recall correctly, doesn't this swap also require a new proportioning valve?
- Han Solo, Star Wars
Offline Challenger6pak
« Reply #9 on: June 05, 2006 - 01:30:36 PM »
Yes, you will need a disc brake proportioning valve also.
Offline 422STROKER
« Reply #10 on: June 05, 2006 - 03:28:48 PM »
You can buy an adjustable on and keep the factory assembly in place  SUMMIT $34.00  it installs in the rear line after the  factory block  Will need adjustment to dial in but once it is, SWEET!
GOOD LUCK
TOM
Tom
Offline R/T hedkace
« Reply #11 on: June 05, 2006 - 05:46:25 PM »
Very cool, Thanks you guys a bunch for the info  :thumbsup: It is greatly appreciated  :cheers:
Now if I could just find two more brackets like the one on the left  :stomp: :pullinghair: :banghead: I cant find them anywhere  :faint:
Jeff
1969 Barracuda
 Massachusetts
Offline R/T hedkace
« Reply #12 on: June 06, 2006 - 04:04:36 AM »
And is this what I'm looking for?  :dunno:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2DG3905&N=115&autoview=sku
Sorry for all the questions, but this is all new to me. Thanks
Jeff
1969 Barracuda
 Massachusetts
Offline Plum6Pak
  • Plum6Pak
« Reply #13 on: June 06, 2006 - 05:55:30 AM »
Yup, Mancini, Jegs, Summit etc. you can get them at just about any high performance auto supplier.
Offline R/T hedkace
« Reply #14 on: June 07, 2006 - 05:18:22 AM »
Thanks man  :thumbsup:  but now I see this  :banghead: page 3, box on the right, WTF  :pullinghair:
http://www.mpbrakes.com/uploads/content/2006%20catalog.pdf
Do I need a combination valve? proportioning valve?
Jeff
1969 Barracuda
 Massachusetts
