Author Topic: Good News/Bad News  (Read 1786 times)
Offline REPOMAN
  • Bustin knuckles
Good News/Bad News
« on: April 19, 2003 - 11:47:35 PM »
 Good news: Dash lights are working now!
 Bad News: Switch contacts must be gummed up!
 Question: do I have to tear all the gauges/insturments out or can some spray contact clean saftly be sprayed in from behind?
I'd rather be BLOWN than INJECTED!
FOUND: Sell slip on my cuda!
$2,000.00 On Dec. 7 1977
Offline 70vert
Re:Good News/Bad News
« Reply #1 on: April 20, 2003 - 12:22:12 AM »
The switch contacts will be inside the switch so you'll either have to take the switch apart or get another one. If you mean the connection between the switch and the harness plug, you'll need to take that apart to clean the contacts. Hope this helps.
We don' need no stinking bowties!!!
« Reply #2 on: April 20, 2003 - 04:33:45 PM »
 ??? Are you reffering to the dimmer switch? It won't take much effort to lower the panel and shoot some tuner cleaner for TV's into it. Just work it back and forth after a good spray and the dust will give way. Hope this helps.
