Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
Crack in head your opinion
« previous
next »
Print
Pages: [
1
Author
Topic: Crack in head your opinion (Read 902 times)
ohio cuda
Jr. Member
on:
June 01, 2006 - 03:28:19 PM »
Okay, I like doing things right and don't believe in the half a$$ method of repairs which is becoming the normal thing. This is a T/A head and expensive. When we cut the head for the hardened seat insert we discovered this crack. Though I don't intend to run this engine on the strip I think it will continue to chase and my engine builder is in agrerment. The guy I bought it from had his engine builder look at it and said put some super dupper epoxy on it and it will be fine. Your thoughts please?
Logged
67Vette427
Full Member
My other car is not a Rambler
Re: Crack in head your opinion
Reply #1 on:
June 01, 2006 - 05:01:48 PM »
Personally, I'd hang onto the heads but run another set. Cylinder heads get pretty hot and I'd hate to see that head ruin the rest of your motor on a really hot day.
I bought a 440 crank recently from a guy that I found to have hairline cracks and he wouldn't take it back... I feel your pain!
Logged
1 of 1 Mr Norm's T/A/ 2015 Hellcat, sublime/ 13 Power Wagon
Chryco Psycho
Administrator
C-C.com Guru
Reply #2 on:
June 02, 2006 - 12:13:51 AM »
you could drill it & put in a plug to seal it up , my guess is it should not leak with epoxy either
Logged
dlrogers
Jr. Member
1971 Challenger 383
Reply #3 on:
June 02, 2006 - 01:24:09 AM »
Yep, probably not too many issues with an epoxy - I's go with the metal fill myself but...either way. I did have a head that looked a bit like that but it was cracked down the valve stem as well - worth checking out a bit more I reckon. If it's all good, go with the fix you're happy with - IMHO
David
Logged
Bay of Islands, New Zealand
Follicly Challenged
Jr. Member
Reply #4 on:
June 05, 2006 - 08:50:47 AM »
That's a tough one, I feel your pain, however that is also a pretty common area to hit water on SB heads when machining for intake seats.
Personally, I'd drop back and Punt !
Your decision.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
